My brother got done for fitment, said the tyres stick out too much from guards and its unsafe, or some BS I think that was when he had to get a engineers
Edit: I mean sure his wheels / tyres were flush but nothing too bad.. so yeah just depends on the officer I guess
lol...
Flush fitment and outside the guards = no longer flush.
outside the guards can get you defected, simple as that.
All it will come down too is the officer at that point in time. Some will get pinned, others wont.
Just remember if you do get pinned/pulled over for it - then it's likely you'll get reamed for other stuff.
I'm a bit fan of less attention, the cheaper/easier your life is :D
i got told my tyres were sooooo stretched it was the "most unroadworthy car" they'd seen in a long time and they could fly off at any time!
infact i was LUCKY they let me drive home they said normally they'd make me get it towed.
so yeh cops dig it alright.
id say if you wana be doin it right aim for about 18x10.5 +15 front and 18x11 -10 rear with 225/35 all round
that's plausable... just... there's an s14 in US that is running 18x12's with 225's and negative offsets on stock metal :D
lol @ alex's car being the "most unroadworthy"....
edit: can he at least run a 40-45 profile? ;)
dey hatin'?
Yeah bro!
How do you know what car littletimmy has and give measurements?
:D
been riding flush and low enough to take out cats eyes with the sump plate in the ceffy for 2.3 years now. Never been hassled by the cops. Don't drive like a tard and they will usually leave you alone.
Also mexican is not just illegal, bros don't let bros ride mexican. Flush is not illegal.
Maybe because you never drive :mad:
i've been defected 3 times in 12 months because of my fitment in my s14.
i always got the story that, if i hit some kid my evil wheels would suck the kid under the car LOL
LOL think of the children before you run flush wheels dude!
lols but at least it looks epic. that's the same bullshit they use for too low.
my front is very slightly sunken, rear is flush with camber then again, car is stock height to doesn't really matter.
avoid certain areas(like knox) and you should be alright.
Edited by Peter89
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
