So basically I was going from a 60 to a 100 zone, car started reving up and making boost and the engine cut out, died completely.
Fortunately there wasnt much in the way of traffic and I had a mates following me in another car (we were going to go camping). The car struggled to turn over, but got there after a couple of attempts but sounded a bit spluttery and the engine light was on. Managed to limp it back home, but I it wont rev much past 2000 rpm, if I tried it would bounce the revs back and forth over a 100-200rpm range and surge almost like a bunny hop. We pulled in to a servo part way back, my mate was low on fuel. I didnt need to fill up but when I went to restart it it REALLY struggled to get going again, almost thought it wouldnt start up at all.
Ive tried to pull the ECU codes, got four zeros. Took the front end off to check the intercooler piping, and also checked the engine bay - all looks to be fine (Im not a mechanic by any stretch though)
Anyone got any thoughts or suggestions as to what I can do/check to isolate the problem?
Cheers!
https://www.sau.com.au/forums/topic/338999-limped-my-m35-home/
Airflow meter?
That thought crossed my mind too, but surely thatd through an ECU code? http://www.skylinesaustralia.com/forums/Ob...st-t281894.html indicates there are AFM malfunction codes.
Hope you get it sorted quickly.
Cheers mate
Sounds like airflow meter Dunc, at least they have been sourced cheap now, around $80 or so new I think. I have no idea why the codes didnt come up...
Can you borrow somebody's to try?
Its possible to check an AFM with a multimeter, isnt it? Maybe I should give that a go
I take it there arent any AFMs that would work other than a unit off another M35?
Quite a few cars use the same airflow sensor but in a different housing, Subaru use it, and many VQ's like maxima.
i let scotty operate on mine too - and they arent repairable as per the older ones.
so will be a new/second hand one
they are available on yahoo auctions japan.
and before you try a 350Z one wont work as the adaptors are different.
unsure about the skyline v35 350gt but id imagine they are the same as the 350Z
mine did the exact thing about 4 months ago.
i was overtaking a car and was in boost when it died mid flight!!!
it was the air flow meter.
I remembered bits and pieces of your thread - couldnt remember the outcome or exactly what was the go. Its reassuring to hear that someone had the same problem and the fix wasnt too costly.
Time to get in contact with Jesse Streeter I guess, doubtful I'll be able to source one here for cheaper than what I can do on Yahoo auctions!
They are available here, im sure Jetwreck got onto a cheap source...
Airflow meter? Hope you get it sorted quickly.
+1 and +1
AFM Nissan part number is 22680-6N211
It should be the same as used in the 2001-2007 X-trail and the 2000-2005 Pulsar
Or you could pick one up on Yahoo... they are routinely on there for under $30 (ex shipping & commission)
Edited by iamhe77
you serious ?
doubt my 98rexy spare afm would suit surely ?
Edited by PetroDola
mate i had the same issues about two weeks ago, i only just managed to get my car home, i took out the air flow meter and sprayed it with contact cleaner and it worked an absolute charm, the car hasn't gone better, it's always worth a shot.
Cheers!
Have you run over anything? like a rock that could possibly squash your fuel lines?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
