  • Replies 106
While we're on the TD subject...
What combination TD 06's have people run as a twin kit on a rb26, rb28, rb30? I'm thinking about going a little ol'skool.
Cheers
Justin
Seen a few Td05 kits, very similar to -5 and 10cm T517z's.
Or twin L2-20gs on rb30 and 2jz, easy 800hp.
I was thinking 2x L2 20g 6cm if I can find a pair-
Raced 10cm t517z's, have a td05 kit and I wan't a little more...
500rwkw+ is goood.
I've given up trying to fing the 'ultimate' hp v's response turbo set up... I just wan't somthing that puts a big smile on my face!
Cheers
Justin
500rwkw+ is goood.
Cheers
Justin
Could go twin T67 25Gs like the JUN Hyper Lemon R33 GT-R lol
Also I pulled my supposedly modified Trust TD07S, and its not, So I may end up using It as Split Pulse T4 manifolds are in abundance for the 1JZ's, So it has the same comp wheel and housing as the T67 but has a larger Rear wheel and a 14cm^2 rear housing, If I can find a 10 or 12cm^2 turbine housing for it Ill be cheering, but so far no luck finding anything smaller than the 14 :ninja:
The 6cm housing in soooo small. I am amazed any turbo cna make power with such a small exhaust housing?!?!?! I had one that I was going to try on my TD06 and RB20. It didnt make it anywhere near my engine bay as the thing was so small that no way could it past 2L worth of air effeciently...or so i thought?@? :ninja:
The 6cm housing in soooo small. I am amazed any turbo cna make power with such a small exhaust housing?!?!?! I had one that I was going to try on my TD06 and RB20. It didnt make it anywhere near my engine bay as the thing was so small that no way could it past 2L worth of air effeciently...or so i thought?@? :)
i tried a 6cm on a sr and it was a disaster ;) so you did good :ninja:
its was a 45 degree power line... not a curve.
These are a few things I found concerning TD06 family turbines .
The thing that I haven't been able to nut out yet is how to distinguish the 11 from the 12 bladed turbines and where each is available ie from TD06 Std/S/H/SH etc .
Mark at GT Pumps should know for sure .
A .
Edited by discopotato03
Don't want to hijack the topic, but since we're on the subject.... what are my options for an RB20 if i wanted a TD06 similar to what Roy is using, but with a T3 flange? The reason i'm looking for T3 flange is because the car already has a HKS cast low mount manifold and external gate on it which i wouldn't mind hanging onto, if only for convenience sake.
I also have a set of HKS cams lying around that i'd like to have a play with at some point. I only mention this because i'm not sure if this should effect the turbo choice now or if its something i should just worry about later on.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
