Hi all,
I have for sale one excellent condition AP Racing Front Brake Kit.
This is a complete top shelf straight fit front brake upgrade kit for BNR32/BCNR33, and should also be able to fit all Skylines and S14/S15 etc.
The whole setup is in excellent condition and only 8,000 km's old, and includes big AP Racing 4 Piston Calipers, 330mm Vented 1 piece Rotors, pads, good quality Japanese Braided mesh Brake Lines, Caliper Adapters, and mounting pins/plates/hardware.
Absolutely awesome upgrade!
I am asking $2250.00
Pickup available from North Sydney
Reason for sale? Going bigger :ermm:
Cheers
how much wider are these than the stardard caili's on a 32 gtr? ive only got about 6mm clearance off the back on my spokes. And what did u run on the rear?? did it affect the bais of the brakes??
very interested
very interested
Hi mate, these can be run as a front kit only and match up nicely with a set of R33 rear brembos - This is a pretty common setup.
As far as width goes I haven't measured but I wouldn't expect they are any wider than an R33 brembo caliper.
If you are in Sydney and want to have a look and measure you are more than welcome.
Cheers.
ive only got the factory r32 gtr brakes on my car atm, would they be too much front vs rear if i kept the stardard brakes on the back??
I wouldn't think so no
Nice caliper and being a single piece rotor and a second hand kit you dont have to worry about noise etc like you do if you buy used 2pc rotors.
Here is the info on the caliper... http://www.apracing.com/drawings/cp5200_1cd.pdf
You wont have any bias problems with these as they actually have smaller pistons then the std Sumitomo R32 calipers meaning that they get their increase in braking performances courtesy of the larger diameter rotor...so bias will be about the same as std, only with better ability to disperse heat during heavy use
Edited by Roy
Just wondering, how much work is involved to have this fitted to a R34 GT-t would you know?
I have verified with Just Jap in Sydney that there isn't a lot of work involved at all.
To fit Brembos or another kit such as this from an R32/R33 onto an R34, you will need sleeves for the mounting holes (R34 mounting bolts and holes are larger) which they can supply from Japan for you.
Cheers.
You need to stop tempting me with all your parts!!!
Lucky i have no money :P
goodluck with the sale!!!
Thanks Nick :P
Still waiting for someone to give them a new home
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
