You're really doing this well and I admire it. Despite this, I am glad that mine came with very few body defects.
to be honest I have worked on much worse over the years that people were still driving around.
a FC holden wagon springs to mind. this came into a strathfield workshop in sydney and you could see through the floor once they moved the sheet of plywood around!!
the areas I can doing on this car are getting done because I want a straigh clean car. somthing I cannot find as most of the cars I have worked on in the last 11 years (I am talking 32's here) were rusted on the rear window, sills or cut/shut. that applied a LOT more to green plate cars.
as you can tell its all about the experience. I am not a chequebook racer and anything I can do myself I will.
those that know me personally pick up on that immediately.
the only part of this I cam not doing is spot welding it back together and painting - simply because I do not have a stable enough hand to wield a paint gun - frank at GT motors does!
2nd shot of roof panel being removed. there are at least 30 spot welds across the front of that. I have got the use of this cutter down to an art now.
the lower support panel does not have a single mistake in it.
another shot.
the brass seams are going to be cut with a dremel tool. a die grinder will be too big to trim those 4 points loose. the front corners are about 4 cm long and those will be fairly easy to do. the rear sides are 15 cm and possibly a pain in the butt. we'll see.
How are you going about the issue with the sunroof as per our discussion mate ?
Its good to see you are really pulling it down and getting the dodgy spots sorted, I hate seeing stuff just bogged up !
Im going to have to get my sills looked at at some point because idiotic previous owners of my car, decided that the little seem that runs along the bottom of the sill is an awesome place to jack the car from, Que surface rust.....
Edited by Nee-san
thats what was done here. believe me if the panel shop had to cut that car apart then reassemble it the cost would be a 5 figure exercise. I already know the cost of the panels involved (its the entire drivers side) and that isn't exactly cheap. in regard to crushed sills - cue $1k in sill panels and another $1k or so to fit them.. I am doing the cutting on mine and the panel guy is going to put them back. saves some of that bill.
after 10 minutes with a angle grinder GENTLY trimming around the brass marked edges of the roof panel - its loose.
and its off.
side shot. drip rails (top middle of door frame) still need cleaning out.
right side shot
right side front corner - the goldish line is brass filling. I still have to clean that up so the new panel fits correctly
upright shot. this is more for my reference to mark what the panel looks like. note rust spot in top right corner,
rust spot as seen from the bottom. this is the reason I pulled this panel off for replacement. it would cost as much to fix it (and have it rust again) as a new panel would cost. so I cut this off off. my aim is to do this once only.
removed panel. the worst part about getting this thing off were the areas around the drip rails at in the top middle of the door glass. they are VERY small spot welds and to get them off properly requires a dremel. angle grinder is too heavy for the job.
rear drivers quarter is next once I get my panel dimensions book. until then it gets a car cover tossed over it. I will still be working on it but in smaller ways. all the small brackets are going to be bought whilst I wait for this book to arrive.
R33 is here:
http://i64.photobucket.com/albums/h191/hakosukajd/R33dim.jpg
R34:
http://i64.photobucket.com/albums/h191/hakosukajd/R34dim.jpg
thats PART of what I am looking for. I still need more and the points that they use to measure from. the diagram is a bit vague to me.
pass. if I wanted a convertible I would have kept a varietta for a bit longer. I have a RAW that keeps giving them to me for a few weeks at a time. thats about as long as I can stand them - no space for anything.
yep. I'm not one to back down once I start something.
new dash,carpet,boot trim/carpet etc - arranged :)
no to the convertible idea. this thing twists enough with the roof panel off ..
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
