At long last my wheels have finally turned up, thanks to everyone who polled to pick them, I am very happy.
As FATZ would say they are the SHIZZLE!
John from UAS thinks they are crap, but hey who would listen to someone who still drives a 300Z boat!
Some pics, enjoy.
I just need to pind some black centre caps to finish it all off!
I now have a pair of STD R34 rims for sale, I will post up soon.
https://www.sau.com.au/forums/topic/340241-ozgtrs-new-bling-a-ding-ding/
John from UAS thinks they are crap, but hey who would listen to someone who still drives the ugliest pos I ever saw!
Some pics, enjoy.
edited for trooof.
Porn wheels mate.
Off course they do, I assume they are just stick elastic bands?
lol
Are the weds actually painted blue on the inside of the spokes or is it the same colour all the way through the wheel, and just changes based on the angle?
fark they look good!!!
wow, bankstown spec! :banana:
They look tuff as paul!!! Very sexy! You some a think blue stripe down the sides or something to match. very jap spec! PM me next time you're planning on hitting the creek, I'll come down to say gday and take a closer look
lol
The blue groves are machined out of the black chrome and anodised, and yes depending on the angle depends on how much blue you see. They do their best work in motion, the blue comes through as a glow from behind the wheel. I have not seen it yet but the misses said it look like it has a fluro light behind the wheel.
Looks hot :P How much are you looking at selling the old rims for?
I was told they are worth about $2k so I assume something just under that. I was going to get them re-painted to look brand new, but apparently X-clusive colours has moved on so I will need to find someone else to do it.
Wow, you gotta let me know the next time its at work so I can pop down and have a lookie in person.
They look hot!
My car has not been at OCS in months, I only realy use it to get out to customer site or if is pissing down on my OCS days.
wow, bankstown spec! :P
Matboy, the only time Im out at the creek now days is to race my push bike! I have not been to a track day in about 6 months!
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
