Hey guys,
Recently I got bit by the rice fever and threw on a kit for the 34 GTT. Kit is sweet as, I'm happy with it, but the problem is that the car sits too damn low, I cannot get it into the driveway, and is almost undriveable(my area has too many humps. TOO MANY!!). I am running on TEIN superstreet. I got the springs wound to let the car sit tight, had a mate put some spacers in it, now it sits about the height of 1 iPhone off the gound. I need it to be at least 1/2 or 3/4 an inch higher. Anyone got any ideas? I have been told I should change to height adjustable coils(top and bottom), but I'm quite clueless as to which coilovers are height adjustable. Please, anyone, help..? :devil:
https://www.sau.com.au/forums/topic/340500-car-is-too-low-fml/
They are only 'preload' adjustable not base height adjustable. By making the preload harder it will raise the car.
Got some pics of how low it is? I never thought my Superstreets went low enough personally.
They are wound to the max and even have spacers to make them sit higher to raise the car. I'm gonna get pictures first thing tonight!! Meanwhile, anyone can point me in the right direction for a decent set of height adjustable coils??
You could either change the springs or get a suspension shop to "reset" your current springs to be longer. If you find the current ones to soft or too hard then going for new ones will give you the opportunity to choose a different rate. Fulcrum suspension are the Tein distributors in Australia, so it might be worth giving them a call.
BTW There's no such thing as height adjustable coils (springs?) just height adjustable coilovers, which is what you have.
what kind of body kit do u have to make it sit that low?
i have a pretty full on kit with coilovers and 18's and my car sits at a drivable height.
i used hsd coil overs.
HSD's are base height adjustable so you have much more choice on how high the car is. Mate has HSD's in his s15 and he can lower it just with the base height adjustability to like scrape along the ground or be like a monstertruck
Yep, was told by the garage the exact same thing. I love the ride at the moment, its very comfy as a daily driver to and fro from uni, yet still firm and very very balanced for 'those moments'. I did put longer springs in them, and now I've gotten another 20mm which makes the car driveable, but it is insanely annoying having to creep over EVERYTHING while worrying about the diffuser and bar snapping off.
The kit I've got on is a full JSAI Ztune kit. Huge front bar, really aggressive and have since got lots of reviews from friends. Stupid payoff for the rice is now practicality. :P
Kinda off topic I know, but does anyone is southside brissy looking to do a photoshoot? :P
who the hell raises a car unless defected.
man up and learn how to drive.
People who want to fix crappy handling as well, for example, if you're into track instead of rice. I have all the extra adjustable arms/bushes (so could get the basic camber/castor/toe correct), but raising the front from 335 to 350 (ie the 350fr/340rr recommended on this forum) made the car both more comfortable and handle better. Something to do with the more esoteric stuff like roll centers I guess but I haven't read up on that, so I don't understand it. All i know is - the 350/340 recommendation came from people I respect, and it worked for me.
by the sounds of things his car isnt that low at present anyway as 1 iphone standing up is what almost 100mm? thats barely inconvenient.
im also no expert but id say a gtr to a gtst would need different set ups. But thats just a guess.
Yeah true on both points. I dont know how to interpret the iphone measurement - he should state the wheel centerline to guard since its what gets used here. If he has a full leb kit then all bets are off.
Pics?
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
