This is my mates one with the same mods.
Interesting points yours makes more power down low and my mates one only starts to get in front from 130km/h onwards. Your dyno seems to stop early, do you have different diff gears?
Could it be your cam gears have been adjusted for more low down power instead of up top?
  • Replies 62
Posted Images
For all i know the diff gears are standard...
you could be right about the cam gears being adjusted for more low down
I am getting the car on a different dyno tomorrow should be interesting
Put the car on the dyno today result was 194, will be getting a retune by another workshop next week.
Not happy with 'recommendations' from first tuner to do a way with the stock airbox as it's cause of alot of restriction.
Ohwell I guess this is how you learn where to go...
Heh - i'm running 305kw with the stock 32 air box, so yeah that tuner is a muppet. (though i did take the plastic snorkel that sits on the outside of the engine bay near the headlight off).
Can you please PM me the tuner's name?
Also, if you don't want to iterate through tuners to find someone good, just go straight to CRD or Unigroup :D Or come to the Unigroup tuning day and learn to do it yourself. You might even be able to have your car used for demo so it gets a tune at the same time!
Better that than 300kw and pinging its head off like one so called reputable workshop in Sydney did to me...never ever forgive them for that. I saw knock readings up to 190 and had to drive very conservatively until I got a new tune from a person that actually knew what they were doing and weren't in it just for the $$$$!!
I would have taken it back, but why??? Wasn't letting a load of muppets play grenades with my skyline again.........once bitten twice shy!!!
I think you will see a better result from another tuner, or at least a valid reason why the power figure is low - thus giving you some direction.
I was running 245rwkw with my old std motor, mods were power fc with std afm, adjustable cam gears and a 3" exhaust with a guttered cat, was using 14 psi of boost, also still using the std air box.
Although now with a new forged engine, not to much has changed except turbos and 20 psi of boost, now running 340rwkw, still using the std airbox.
Your power levels seem a little bit low to me, it would be interesting to hear the results and opinions when you take it to a new tune/workshop.
Good Luck!
Also, if you don't want to iterate through tuners to find someone good, just go straight to CRD or Unigroup :) Or come to the Unigroup tuning day and learn to do it yourself. You might even be able to have your car used for demo so it gets a tune at the same time!
You have PM
Thought about CRD but the workshop i am going to have really helped me out and made time for me to check it all out.
Better that than 300kw and pinging its head off like one so called reputable workshop in Sydney did to me...never ever forgive them for that. I saw knock readings up to 190 and had to drive very conservatively until I got a new tune from a person that actually knew what they were doing and weren't in it just for the $$!!
Yea i wasnt going to go back to him again, just for the reason that it could get worse.
When i went today they also still had my previous power run when i first bought the car on file, they were shocked and straight away saw the problem and reassured me that it will get fixed
Do you still have the compliance cat in the car? if so then thats the answer of why you are 30 killerwasps shy of most others
I have a 100cell highflow metal cat
Good Luck!
Thank you for the support im still new to all this but hey its all about learning right!!!
And a big thanks to everyone on here really appreciate it and will update you when it gets sorted :)
Nick
holy crap 190? didnt know u could get a reading that high LOL most ive had is in the 80's. 100+ must be the ping that u can actually hear as a rattle??
Not to hijack thread, I only did one agressive accel in 3rd and one hill in 5th. After that I learnt that if you didn't load the motor up it was fine. I drove it like a deisel truck until I organised another tune. If they had ever tested their tune on the road they would have seen what they did with no real effort. And they had the car there for a fortnight [i had to drop it off and leave, I work away a fair bit].
A friend on here told me of his Nistune tuning not long ago. The tuners had apparently done WOT tune and nothing else. The rest of the map was pretty much standard. I lol'd at the lack of effort from this tuner.
what was the problem that they identified?! some form of restriction?
they saw straight away that the rune was crap!!
There is no restriction, and seeing that it is running 2psi more then when i first bought it (due to exhaust) just shows he did a half assed job
happens a lot more often than you think
    • Agree with Rob. I recently did mine and replacing with a brand new unit made the most sense compared with rebuilding my existing gearbox.
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
