"dimple" Neodymium Magnetic Sump Plug Group Buy!
Hey guys
Given that the AUS dollar is doing so well against the US dollar I want to do a group buy on the Dimple magnetic sump plugs to bring costs down to a reasonable amount.
Now for some the brand Dimple will need little introduction but for the most of you, you have probably never heard of the brand; but you have all most likely heard of magnetic sump plugs. I have always wanted to get a magnetic sump plug due to how "cheap" most of them were and I usually spend around $100 a service with Motul oil, filters, plugs etc, and figured what the hell, why not. It wasn't until I started doing a bit of research (like I always do prior to buying something new :P ) that I realised why most were so cheap and made in China...
Why would I need a magnet in my oil you may ask...
Every time you run your engine, it becomes more and more contaminated with many thousands of tiny nano particles of harmful ferrous metal. These metal particles are so small that they cannot be seen by the human eye. They are mainly caused by friction and lots of it. For example an engine travelling at merely 2000 rpm sends the pistons up and down 33 times per second.
The human eye can only see a particle 40 microns or larger. The oil filter can only realistically filter out particles larger than 35 microns. The particles we are looking to catch with powerful oil filter magnets are about 35 microns or less in diameter, the smaller the particles the more harmful to the engine because they travel everywhere under oil pressure, and act exactly like a fine lapping compound, continuously polishing down all surfaces.
I have supplied a lot of information down the bottom including technical information and videos on the Dimple magnets due to their being quite a lot to learn. Feel free to have a read to get a good understanding. I'm trying to keep this post easy to read and short but it is quite hard given the amount of information I want to put out. I actually came across this brand while researching the cheap magnetic sump plugs you buy and found a lot of good information on how crap they were and in some cases very dangerous doing a lot of harm! The Dimple brand was mentioned very positively on a lot of the US/Euro BMW forums and on nearly every motorbike forum. Nearly all agreed, once the information was laid out, that the cheap ones you generally buy were pretty useless but the proper expensive ones made by a few companies were definetely the go.
So first lets start on the cheap ones you get and why they are cheap.
First of all most use normal magnets that you get in day to day life. This is because strong magnets are expensive (just like expensive car speakers use expensive magnets). These pretty much do nothing. Their magnetic strength is so low they can not pull small metals from the oil when the engine is running. Some slightly more expensive ones will claim they use Neodymium magnets (in some cases they are lying) however these are still cheap neodymium magnets that once they get a bit of temperature in them (around 79 degrees celcius) they loose their magnetic power and once again do nothing. The main problem with this is while the oil is cold, the magnet might be doing its job and start collecting swarf onto it self pulling it all together into one clump. Then as soon as it heats up it looses the magnetic power and lets the clump go. Now you have a nice chunk of swarf..
Now for some more dangers. Nearly all cheap ones use an alloy bolt to attach the magnet into. The cheapest way to do this is to press the magnet into the bolt. It is very possible for the magnet to work its way out of the bolt under high heat and pressure (like giving your car a good thrashing at the track) and get into your engine!
So you can easily see, excuse my french, that most cheap ones are shit. They are made in China on a budget for large profits just like everything else and the comapnies aren't really that determined on making a product to do its job properly. (If you look on Ebay you will see nearly the exact same type all from Hong Kong and being sold in Australia)
So onto the Dimple brand
These are made in the United States for the sole purpose of being the best magnetic sump plugs you can buy and to catch every single loose bit of metal in your oil.
The Dimple super drain plugs are the strongest high temperature magnetised drain plugs available, period. Dimple products use extreme magnetism to rip the metal particles out of your oil. Dimple magnets are made under contract to insure that they are always the strongest high temperature grade neodymium magnets in the world.
The Dimple magnets are created to keep magnetism in excess of 180 degrees celcius.
Dimple magnets are some of the only ones recommended by the Society of Automotive Engineers (SAE).
For some one that is planning on building a new engine or has a new engine these really are a must! But for anyone like myself that just cares about their cars well being and wants their expensive oils to be doing their job and to be as clean as possible with all the help you can give them, than why not? It really aint that much money considering how much they are doing for the life of the vehicle.
Now for the group buy!
We are getting Dimples brand new SS design which has only just come out this week for our thread M12 x 1.25. These use a brand new metal to metal seal with on o-ring for a gauranteed leak proof seal with no gasket (washer) required for the life of the bolt. They are temperature and vibration proof and will reseal perfectly every time. Therefore you buy one now and you never need to buy another one ever again.
These are going for around RRP$50-$60 delivered from the US or the UK.
If we can get 20 people involved the price will be around $35 delivered Australia wide or if we get closer to 30 people around $30. I will give an exact price in a few days time once I get the freight qoute from the US.
I will keep the group buy open until the 8/11/10 to get the numbers but may change the date dependent on how things go. I will than require payment within one week from the group buy closing and will transfer the money to the US.
Here's some good info on these sites:
http://www.drainplugmagnets.com/magneticdrainplugshome.html
http://www.magneticoildrainplugs.co.uk/index.html
These are by Stewart Sanderson who is a known and respected automotive motorsports technical author for many European automotive magazines
And this one by Chris Waddell, one of the best Harley Davidson tuners in the USA.
Here's a third party lab report comparing a factory Harley Davidson magnetic sump plug to a Dimple one. (The Dimple one was 1,435 times stronger!)
http://www.drainplugmagnets.com/images/CRT...mple_report.pdf
Thanks guys
If you have any questions feel free to ask :P
Phil
BUY LIST
1. PMR33
2. …………
3. …………
4. …………
5. …………
6. …………
7. …………
8. …………
9. …………
10. …………
11. …………
12. …………
13. …………
14. …………
15. …………
16. …………
17. …………
18. …………
19. …………
20. …………
Edited by PM-R33
  • Replies 200
Yeah its just a universal bolt and they come in different sizes. I'll find out what size our gearbox and diff uses.
Edited by PM-R33
Going good so far! Might get to 30 afterall :)
BUY LIST
1. PMR33
2. 75COUPE
3. BASTI
4. MOODLES2
5. 33DRIVER
6. 89CAL
7. DARK-KNIGHT
8. PWND
9. R32MAN09
10. LUKAS 33
11. …………
12. …………
13. …………
14. …………
15. …………
16. …………
17. …………
18. …………
19. …………
20. …………
Edited by PM-R33
I don't think 30 is going to be a problem! I'll speak to some more of my mates today because i'm sure they will be keen aswell.
If any one knows the diff and gearbox bolt sizes post it up. I can't seem to find the bloody info anywhere.
BUY LIST
1. PMR33
2. 75COUPE
3. BASTI
4. MOODLES2
5. 33DRIVER
6. 89CAL
7. DARK-KNIGHT
8. PWND
9. R32MAN09
10. LUKAS 33
11. CHRIS32R
12. GIMPS-R34
13. FINELINE
14. N1GTR
15. SKINS
16. THENIG
17. …………
18. …………
19. …………
20. …………
Have you got any more information form the supplier in testing in an actual engine? I wouldn't mind seeing it pull the particles of Iron in a normal running engine. If it does what they say in an actual engine, then I would be interested and would probably take a few off your hands.
The guy in the harley vid has massive particles of metal in that container. If you have that kind of material in your sump then you have more issues to worry about. The second vid shows a 'mock' sump with, once again, large particles of metal being poured in.
In the lab tests we have done on engine oil from Gervase's race car and Noel's race car we generall see 15-20 ppm (parts per million) of iron, which is basically the only magnetic material it will have during wear.
Considering oil is designed to suspend these particles I would be interested to see if it can pull these microscopic particles from the suspension of the oil. Do they have any videos of that?
I can ask. The guy that makes them in the US is very nice to talk to so i'll see what he says :)
But you are exactly right, they are made to pull the particles smaller than 35ppm that an oil filter can not stop. If an oil filter could filter out particles that small, no oil would be able to flow through the filter.
Edited by PM-R33
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
