"dimple" Neodymium Magnetic Sump Plug Group Buy!
  • Replies 200
Righteo pictures are here :D
The Black Hole magnets actually come as a pack of 6 so they go all the way around the oil filter. Richard sent me them to test out, cut apart the oil filter, take photos and show the results of how they work.
In the next batch if people want to order them by all means we can.
Regarding the postage, I calculated it at around $3-$4 if the thickness passes with normal Ausrtalia post. If people want them ASAP however, I can send them in an express post 500g satchell for an extra $5 if that is cool?
If any one else wants to pay an extra $5 to get it express posted to gaurantee it being delivered before the weekend let me know by tomorrow morning.
Edited by PM-R33
Yeah that's fine. The sump plug will be the same as ours, the diff plug you will have to let me know the size though (might be the same as ours).
Is the ones on the skyline just that 13mm square hole? if so yeh i think its the same
Im cool to wait, Not due for a service for another few weeks so no rush, They look and sound good. Sounds like it will probably pull my big end away from my con rod lol.
But sound like they will be a good bit of insurance :D
Righteo I think I have gotten around the thickness problem. Without the plastic vials and when the plug is on its flat side, the thickness seems to be border line lol.
So when the plugs rock up and you are wondering "Where the hell is that plastic vial that he showed in the photo?". That is why. I did however include the little yellow paper with Dimple, M12 etc written on it :D
Hey Phil,
I am happy to hold mine until the clutch line arrives.. would save posting twice.. could prob leave mine in the vial then.. or take it out... if not let me know and i can transfer more monies to cover the extra costs..
also would be down for the oil filter ones along with diff & gb if we can get confirm on sizes.. on next group buy..
All sent! (I sent yours as well Craig, it's all good.)
Hopefully every one gets them by the end of the week, if not early next week. N1GTR I sent yours express so you should get it Thursday the latest.
One thing I was thinking of though, I hope they don't some how get lost by attaching themselves to a conveyer belt or something! They are just so damn strong lol.
As for the next group buy, I will awaite EJD001 to post up details for the diff and gearbox plugs and then start the next group buy than. We can do the diff/gearbox/sump/Black Holes all in the next group buy.
I'll keep every one posted.
:P
Edited by PM-R33
Sump, gearbox and diff really (the diff and gearbox will actually shed the most amount of metal).
I can't think of any thing else? Maybe on a GTR transfer case aswell?
Edited by PM-R33
different thread size again
Yep just got it!
I have to say, it's a lot stronger than I was expecting. Definatly in for the other ones when you do those-just add me straight away and tell me how much :bunny:
Trader rating time :D
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
