  • Replies 226
Anothe point, related to other posts, is that Tirerack shipping is to whatever nominated address you want. Not depot.
Delivered to the address you give them, they are left at my door when I order them.
hey guys for your info been doing some research and found priceusa to be a good company to use i will be giving them a go when i need new tread, plus they are an australian company
Pretty dear though, I have previously used them to import R1Rs
Tiretrack ship free to the US, so free postage to that mob, Then its about a few hundred to get them over here - I think tiretrack quoted me $250 for postage.
would stll be worth while is there was a saving of $500+ if not local looks the way to go now
Nah, the point is that PriceUSA don't get anywhere near as cheap shipping as Tirerack do. Tirerack have got really good freight deals with their various shippers. Almost no-one else gets as good a deal as they do.
Yes very true
But if you are buying tyres that "Australian companies" won't bother bringing in then you are winning and semi slick prices are a massive saving still
  • 1 month later...
Seems Tirerack have changed their export policy yet again, but this time for the better :) All brands are able to be exported to Australia they are just limiting the quantity to 4 tyres per order.
I emailed them just before Christmas and that was the reply I was given.
Mike.
Mike.
NAICE!
  • 4 months later...
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
