nice info from the tuner. it really does look like a gun set-up.
Yeah good to see someone giving some extra information!
The power at 4000rpm is very impressive :)
I'm assuming the "old set up" is a stock 2.0L motor with a GT30ish sized turbo
The tuner posts some very nice and detailed info, that's great.
And wow, better power AND response than previous setup, agreed with SimonR32, looks like it was GT30-based. Win-win.
And it loses nothing to factory 4B11.
i want one now.
Even at 18psi it's an animal to make so much power as early as it does.
I wonder how an rb25 would go trying to spool it....
I would expect peak torque to be a little higher in the rev range but the transient area to be a little better to compensate (think linear inline 6 effect).
Now I want to see a 7064 on an SR, might just have to get one LOL
yeah I wonder how a 7670 would run at 30psi on my Jun RB27? but given how responsive the 9180 was on berrys RB30 I was thinking 8374 for me but if the 7670 can make the power I want (380-400kw atw) then why not use it? I'm still not convinced it's a genuine 600hp/400kw @ 30psi at the treads turbo though but if it is then it's bloody awesome.
Beer Baron - Depends on the dyno you're reading at the treads at, some rolling roads (ie, Dynojets) often read the same if not higher than Dynapacks... depending on the setups of course. This is ~470kw @ hubs, I'd say if this is a genuine reading, then I'd think 380-400kw on a DD should be realistic.
I can't believe how boost thirsty these things are....Hope my engines up to the task :wacko:
Its the EVO that needs that boost to make that power, though I'd still have gone the 9180 for an RB30 personally :thumbsup:
My "410kw" on the same hub dyno with the same correction (SAE) went 360rwkw on a Dyno Dynamics roller...
So I would imagine the 30psi E85 run would be around the 400-420rwkw
Its the width of the compressor map that inspires me to say that more than the outright power numbers - will be interesting to see what kind of power the EFR8374 lets through when not pumping 2+bar through it.
Thanks, but I'm well aware that you've previously posted those results, not really any need for name calling, most of us are adults here.
Maybe on the dynos you use there is a 70kw difference.
I didn't call you a name?
The dynos I "use" is the same dyno with the same correction as the result of the Borg Warner EFR on the last page (so a viable comparison)... It's also the same dyno that STATUS (not from Perth) uses. (battery, with almost an identical set up to mine makes almost exactly the same power as mine on the STATUS dyno as mine does on the Allstar dyno)
It's also worth noting that we know the hub dyno reads higher than a roller, which is why we usually leave correction off. With correction turned off it's still 30kw difference between the hubber and the roller! The 2 runs were also on the same tank of fuel with about 50km of driving between the 2 dynos...
Also in regards to the shot at high reading dynos in Perth, good one... Original, pitty the mph does not lie!
Now you just sound incredibly ignorant.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
