I really hope it's worth it scandy.
Remember back to the early release blurbs about how the integrated bov, boost control solenoid and IW housing options were supposed to make it easier and cheaper to fit one!
So do I mate. Got the bill from Andrew today for the manifold and all the rest. So far this exercise has set me back around $4k... Not bad for something that started out as $100 modify and replace project.
LOL ahh... cars.
"and all ill have to do is change this $5...... $5,000 part" lol yep.
I sold my last car and bought my current car complete, every mod I wanted. Now it only has scraps of the original setup left as nearly everything needed to be redone lol.
Keen to see your results tho, Its a nice kit up you have going :thumbsup:
Pretty well.
More shit. Car came home tonight.
Intake;
Starts at 3" and necks down to meet the 2.5" (?) intake. Trying to source a Pipercross filter with a Z32 mount. Then it's back to Andrew for any necessary mods, and to make up a decent bracket and close it off.
Lobster back hot pipe. Complicated little thing. 12 pieces.
Both will likely get coated wrinkle black to match the rest of the pipework.
And finally, the dump pipe.
I'll have to find a bung for the o2 port. Only there for tuning. I won't be running a sensor.
The dump, pipe, and cat are all 1 piece. So I only have 2 flanges in the entire system. Lovely.
Oh yeah, if anyone in here knows their wiring and SR's, specifically ignition, shoot me a PM.
This thread started 16 months ago..
I want a 8374. But I'm not prepared to wait for the next decade to get it..
What the Fire trUCK is going on..
Well i got my full race mani and BW 83/75 s300sx turbo in about 2 months, and it was only that long because the mani was made to order
Is there some sorta mad waiting list for the EFR's?
production issues actually, havent you read the thread start to end?
no point being interested if you havent
Yea righto mate
I've read the thread and know there's issues, just can't believe there's still a massive wait on a turbo that bearly anyone has..
There's was meant to be a "still" somewhere in my last statement :thumbsup:
lol i guess the 'still' would change everything.
i would assume BW arent in a big rush to roll them out anymore because of the prior issues. they are more likely to provide to a smaller client base for testing (workshops/race teams).
these are still on the map for me but as selfish as it is i want to see more results that show they are more phenomenal than the competitors.
Its very frustrating.
I've wanted one of these since I heard about them..
My other options BW s300 8375.. Bullseye S362 (virtually the same thing) or a gt35 with divided t4 housing.
All of which are proven performers.. And are all roughly the sme money delivered to my door..
Just not sure which would be the best on a daily street driven 1.5j.. :blink:
Just saw this too.. New for 2012.. looks like it could be a better option.
http://www.full-race.com/store/turbos/borgwarner-airwerks/borgwarner-s300sx-fmw-turbo.html
Edited by --Redwork--
Awesome, keen as to hear how that goes... Whats the rest of the setup?
2.6
Ross crank trigger
Link ECU
aftermarket ignitior (cant remeber what brand) need it to run with Link
sard 800s
Full race twinscroll manifold
260cams
Koyo intercooler
Jun pump
adj cam gears
4 inch dump with high flow cat into 3.5 rear
Both the 83-75 and the FMW are excellent bang-for-the-buck, great power and incredibly reliable. The FMW turbo is basically the "new for 2012" version of the S300SX 83-75. it uses an EFR 8374 compressor wheel combined with 2 different blade shape turbine wheels depending on what the application is. here is a photo of the comp wheel:
our customers who cant wait for the EFR 8374 are generally using this turbo
Edited by Full-Race Geoff
So benefits in response and top end in the new wheel design?
Can it be bought and swapped into a 84/75 housing Geoff?
Looks cool to say the least
The S300 FMW shares the identical turbine housing to the s300sx 83-75, 84-75 and 88-75, so yes you can share the turbine housings. the compressor housings you can not swap however.
if you decided to get one, i would suggest to get it with a different housing A/R and different blade shape than the turbo you currently have. the reason is that BW balances the non-BB turbo components individually, this allows you to mix and match between turbine wheels and housings on your turbo, without the need for a rebalance. these S300 turbos are extremely easy to disassemble and swap a turbine wheel on, just 2 wrenches on a left-hand-thread is all it takes
So to confirm iI could keep my turbine housing but I would need to swap out the compressor to match up with the new wheel design?
Is there any back to back testing of the old wheel design vs new?
BTW id be keen to do some back to back testing of the new wheel if i was to be supplied with one :whistling:
i got one of your Full race manifolds as well :thumbsup:
Edited by GTR_JOEY
So the compressor housing can't be swapped because the inducer size of the wheel is bigger... Yes.??
Comparing the 2 compressor maps it looks like the new wheel moves more air even at low boost levels.. But I'm no expert at reading comp maps... :wacko:
You keep your existing turbine housing but its a new CHRA.
The compressor is different and uses a different housing to suit, yet the turbine can use the exiting 75 housings despite being different.
My take on it is you can buy both the front and rear wheels along with a compressor housing and put it all together yourself.
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
