No. It would be good for an unopened motor also, of any variety IMO.
They are about 20 years newer than the 2860, think about that in general technology terms and it should make sense why they are out performing the old stuff.
  • Like 1
Man, If I owned a car that could easily mount an EFR (like a GTR or something) I would be allllll over them I think they are awesome turbos, despite them looking a little ugly...
The fitment on something like an EVO is such a pain.. I'm in the process now of TRYING to figure out how to mount one... but because they are so bulky, its difficult. In something like a GTR, it would be epic!
Nothing a simple manifold cannot fix. Y so srs?
If you get the newer external gate housings it should fit no problem. 4cyl manifolds are easily made/modified.
I am in the same boat once the evo7 is run in, I would like to push the 2.3 stroker to its limits, but lag is a bummer.
If your referring to the Tial housings... they are good, but you loose twin scroll. Which is kinda what you want on a single turbo 4cyl... If not, you should just save yourself money by getting a precision.
Fitting the T4 divided is not that simple. Not for a daily driver anyways. The CHRA is longer then the generic Precision or Garrett offering, and so is the turbine housing. Add this in with the bulky compressor cover, and it is a real struggle to fit downlow.
1. You need to notch the gearbox mount
2. If your keeping the A/C in the stock location (I'm currently looking into relocation or replacement with electric), the radius on the dump pipe would be and is horrible.
Mounting internal (or external gate) in high mount configuration has its own issues;
1. Your moving a significant amount of weight HIGHER in the front of the car. It doesn't promote good handling.
2. The 'lower intercooler pipe' or turbo to intercooler pipe has increased length over a low mount, thus kinda defying the whole point of using an EFR - Loosing transient response
The actual construction of the manifold isn't that hard, its more how everything sits. If you can manage to relocate the A/C to give you a better radius on the dump pipe, it would be perfect....
Edited by Tonba
I initially though they were airwerks due to the fact the FMW compressor wheels are apparently the same wheels as EFRs.
But then I saw the pic of what they actually run, which looks to be a custom casting.
borg-warner-turbochargers-used-in-the-iz
Anyone found out if we can get these yet?
I can tell you, keeping the split pulse is nowhere near as important as getting the Ti wheels in there. I will be going a single pulse manifold if nothing twin is available by then, as I believe the whole split V single debate is a bit of a crock.
Externally gating off the housing opens up so many more options, and if the compressor housing is bulky and gets in the way, it will be modified.
I will definitely be low mounting, whatever the turbo I end up with, but if you are seriously worried about a couple of kg mounted 6 inches higher, you have issues. The turbo fits where it fits, and it's my job to make it work.
Dump radius, I have yet to see a good one on an Evo. :P
I disagree with a few things there. First off, the whole point of the EFR's is that a whole lot of little things come together to make a noticeable result. The compressor housing is bulky because of the integrated BOV. Now, sure you can modify it so the BOV doesn't exist, BUT the BOV outlet is positioned to 'vent' on the back side of the compressor blades. What this does is on release of throttle, the air vents onto the compressor wheel, to help keep the momentum of the assembly up. In combination with this, you have the light weight turbine AND compressor so the effect of the BOV is greater.
In addition to the above, the twin scroll housing assists in transient response as you do not have exhaust waves/pulses fighting against each other. This minimises losses here.
The light weight turbine is only a piece of the puzzle. Sure you might notice something with it only, but the effect is multiplied with the integrated BOV and twinscroll.
In regards to the high mount, while most people mounting the turbo this way in a street application, wouldn't notice the change in weight distribution, they WILL notice the increase in intercooler pipe length as it contributes to longer spool times and longer transient response time, in comparison to a low mount setup.
And I do agree, Evo's generally have poor dump pipe designs.. so where is the harm in trying to optimise this area?
Edited by Tonba
It is so nice when people just make perfect sense!
And Tonba one thing, I can tell you right now that if ppl weren't so scared of axial loads on the compressor wheel causing damage (however manufactured they are to sell product i.e. BOV's) then no one would have them.
Light weight wheels are the biggest part of the puzzle because it is minimising the rotating mass which would have the most direct effect on 'transient response' (just to quite the most recent buzz word going around here).
Agreed Michael.
I don't want a BOV on the compressor housing, or a stupidly long internal gate housing. I have a Tig welder handy which can place both exactly where they need to be to fit.
What I am looking for is the EFR pictured above, Tial housing and all. The shaft speed sensor can even get farked.
  • Like 2
The BOV is incorporated for only one reason, the shaft would fail if you didn't run a bov at a guess, too brittle.
Yes, not like the big beefy Airwerks series based on diesel applications...
Ever seen a BOV on a 600hp CAT engine? Fair enough they don't throttle on/off like we would.
I would only keep shaft speed sensor location just to make sure you didn't exceed recommended limits.
And what, buy a new ECU just so I can log it? I would rather keep the cash aside for a new turbo if it lets go.
Limits were meant to be exceeded. ;)
Borg Warner broke the existing turbocharger mold when it created the EFR line. One of the main goals was integrating other turbo system components into the turbocharger. This ploy can save time, money and headaches. The biggest integration is the inclusion of an integrated blow-off valve. No more bung welding on delicate intake pipes. The BOV is laid-out as a compressor recirculation device that redirects the charge air from the turbo's compressor outlet to a low-pressure point just before the compressor inlet, which really helps keep the unit spooled between shifts.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
