Genuine R34 Gtr V-spec 2 Aluminium Pedal Group Buy!
I have a list with every ones name written down for the next group so don't worry, I won't forget - hopefully :bunny:
I would rather not collect money yet until I start the next batch (which will be once the first batch arrives in around 3 weeks time). Just makes it easier for me to track payments.
Definitely in!
Guessing by the interest that you have for these there will be a 3rd and maybe 4th order for these. If you do have ones organised for early next year then I will be interested for my RS4S Stagea. Would look good and just another thing to add for it's time off the road. Thanks greatly. Keep up the great work.
Yeah definetely hoping so!
I emailed them on the weekend so hopefully get a reply tonight/tomorrow to see what kind of ETA we have.
Can't wait!
Can't wait!
Hey mate, any updates for the first group?
They are still trying to find out the ETA from their supplier.
I will send them another reminder tonight to see how things are progressing. I'm starting to think they might not get here before Christmas :(
All the pedals are ready, they are still just waiting on the footrest pedals.
Hopefully hear back from them by the end of the week to see where we are at.
UPDATE
The pedals are arriving to the US some time in the next two weeks.
Once they arrive they are getting sent here.
So as I said, looks like it will not be until after Christmas :(
Lol not yet :P
I want to make sure they all arrive correctly first.
I have let Adam known that we will be doing more orders so to let his supplier in Japan get more ready and it shouldn't be a problem.
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
