Bought and installed a new battery today (with larger terminals to suit, and a new battery clamp to hold it in). I now have 610CCA's of juice available to kick my starter motor in the guts!
what shade did you go on the window tint josh? darkest legal? just wondering how it looks against the stock rears shading.
we went with the darkest legal shade which here is 35%- I like having a car that doesn't get picked on by the cops (yet). It looks pretty good. You can tell it's lighter but there's not a huge difference. But then that could also be due to the front windscreen being so light? I'll try to get a decent pic of it.
(sorry for butting in :blush:)
Edited by Cheddar
I used those TRW Lucas pads in R32 GTR calipers on my R31, very nice, from stone cold to the hardest I could push 'em.
Get used to washing those wheels; they're dusty buggers...
:blush: some ppl were saying that they aren't too bad but i've noticed a fair bit of grime already
i'll probably swap them out for the qfm hpx when i've got the money or am sick of washing the wheels
;) some ppl were saying that they aren't too bad but i've noticed a fair bit of grime already
Get a can of Autoglym wheel seal for your rims, then you'll basically be able to hose the dust off.
(sorry for butting in :D)
lol jo. it is your car after all :) i'll keep an eye out for the pic.
On the weekend I finally go around to fitting the carpc into the wagoon, had already fitted teh screen previously when I put the CB in but had a couple of wiring issues.. got those sorted out yesterday so now everything works mint!
Must say, I've missed having a carpc!
Oooh, post photos when you're done, please!
Last night finished fitting new tie rod ends to the Stagea. This morning had a full wheel alignment done. :P
Saturday the Stag gets a brake upgrade ... Sumitomo 4 pot calipers and 297mm rotors ... Lucas pads :)
put in my tranny cooler, hard suction line to turbo, turbosmart BOV (couldnt be bothered with having to plumb back the standard BOV) and also dropped the front drive shaft,
definatly fun times being RWD but pretty just doing it to make it easier for when i get it tuned soon,
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
