Bought and installed a new battery today (with larger terminals to suit, and a new battery clamp to hold it in). I now have 610CCA's of juice available to kick my starter motor in the guts!
what shade did you go on the window tint josh? darkest legal? just wondering how it looks against the stock rears shading.
we went with the darkest legal shade which here is 35%- I like having a car that doesn't get picked on by the cops (yet). It looks pretty good. You can tell it's lighter but there's not a huge difference. But then that could also be due to the front windscreen being so light? I'll try to get a decent pic of it.
(sorry for butting in :blush:)
Edited by Cheddar
I used those TRW Lucas pads in R32 GTR calipers on my R31, very nice, from stone cold to the hardest I could push 'em.
Get used to washing those wheels; they're dusty buggers...
:blush: some ppl were saying that they aren't too bad but i've noticed a fair bit of grime already
i'll probably swap them out for the qfm hpx when i've got the money or am sick of washing the wheels
;) some ppl were saying that they aren't too bad but i've noticed a fair bit of grime already
Get a can of Autoglym wheel seal for your rims, then you'll basically be able to hose the dust off.
(sorry for butting in :D)
lol jo. it is your car after all :) i'll keep an eye out for the pic.
On the weekend I finally go around to fitting the carpc into the wagoon, had already fitted teh screen previously when I put the CB in but had a couple of wiring issues.. got those sorted out yesterday so now everything works mint!
Must say, I've missed having a carpc!
Oooh, post photos when you're done, please!
Last night finished fitting new tie rod ends to the Stagea. This morning had a full wheel alignment done. :P
Saturday the Stag gets a brake upgrade ... Sumitomo 4 pot calipers and 297mm rotors ... Lucas pads :)
put in my tranny cooler, hard suction line to turbo, turbosmart BOV (couldnt be bothered with having to plumb back the standard BOV) and also dropped the front drive shaft,
definatly fun times being RWD but pretty just doing it to make it easier for when i get it tuned soon,
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
