Picked up my car this morning, resplendent in new heatwrapped mid pipe, 100 cell hiflow cat, and shiny Fujitsubo exhaust fitted. Now it's 3" from turbo to tip.
Canak Autosport did a beautiful job on the mid pipe; tucked up nice and close to the floor, out of harms way. Cost a little more than I expected, but there's almost $400 in cat, flex joint and flanges.
Sounds brilliant, no drone, just a sweet rumble at idle, and nice rasp as you rev out. Now pushes almost 15 psi instead of 12, feels so much more responsive!
One very happy camper.
Good stuff Dale...
Picked up some 33gtr swaybars last night, will chuck them in on the weekend and pull the diff out to be dropped to my diff guy on Tuesday... SkidWagon is getting close.. BRING ON POWERCRUISE!
Bet that sounds shit hot also Daleo..as well as looking quite smart! *thumbs up* :O
Im actually wondering if the HKS suited for the M35 sports muffler on my full 3" system from scotty actually gives more power than the fujtsubo / kakimoto M35 systems. I know the Fujitsubo and Kakimoto's have a much nicer quieter tone. (bit like a rexy bob)
My question is would there be any difference as mine is like 50 times louder?
Edited by PetroDola
I think it comes down to the design more so than how loud it is.
Both the Fujitsubo and Kakimoto exhausts are designed to flow as much air with as little restriction as possible while their muffler setups use vastly different designs to control the sound/volume
I think that the only way to tell if yours makes more power would be to dyno them back to back on the same car.
You can't look at Scott's dyno results for a comparison between the two because he changes shit on his car every second day :O
Edited by iamhe77
hrmm good Point Iain.
Im wondering if scott has any dyno's done with just that exhaust mod from stock :huh:
and what impact it had...would be interesting to know the difference for sure.
Cheers!
Had the 260RS profesionally detailed today. Got the lot done for $300 which I recon is bloody cheap! Then brought it home and polished the GReddy intake pipes. Man I love this car even more now!! :)
A bit lame but bought some 15mm hubcentric spacers from JustJap.
Matt@JustJap had them delivered to my door within 3.5hrs (ordered 10.15am sitting on the doorstep at work by 1.45pm). That is outstanding service and deserves a pat on the back.
I have a HKS2835ProS going on next week to replace the perfectly fine HKS GT-RS which will be a more interesting mod. More on this next week.
Im wondering if scott has any dyno's done with just that exhaust mod from stock :D
Cheers!
I asked for the system to be fitted when I bought the car so no pre graphs, I cant even remember what it drove like... I think the words were "4 cats, you are kidding right". :blink:
Cheers!
Im pretty sure you replied to Cam's post and not mine mate :P
its not like we are remotely the same, he has a gay coloured car!!
lol... and you have a stock kinda car (or is that a "gonna" kind of car :laugh:) with an old-man interior!
Anyway, minor-ish service on my Stag today - oil, cleaned intake and a/c filters, changed plugs etc, etc...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
