hmm picked up my BC coilovers, greddy boost controller, HDi FMIC arrived at the office!!
come on nismo products from japan!
A busy night in the garage tonight? :P Pics to follow I hope!
haha busy indeed!
tell us if you notice a difference with HDi FMIC .. i actually noticed more lag in the short end because of the stock turbo. but pickup in the middle range top end when it was cold at night (bearing in mind qld winter is 25C)
hopefully that will change with the hiflow.
got some tuning nuts today and replaced the stocky nuts with all 20 of the tuning nuts.
Should be a good deterrent for anyone attempting to steal the rims as theyll need to get all 20 off without rounding the nut and that wont be easy.
and ordered the centrecaps from rays.. $200.. (rip job)
Can park out front without being overly paranoid now!
Edited by PetroDola
Are they the Taleb tyres ones?
I bought a set, finish was nice, but I ended up running at tap down them as the threads were fairly gritty. Check them before you fit them.
hi duncan , not sure what brand they are , i got my tyre friend to source them for me from mullins wheels in SA (the bag had no brand names), but they were really good nice threads and clean.
i needed quite small ones for the key not to scrape the rim as its really narrow
Edited by PetroDola
haha im not going to install till the brake rotors arrive, then ill do brakes and suspension at once to save wheel removal time
i wish i could have done it tonight, had photo comp to go to instead
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
