hmm picked up my BC coilovers, greddy boost controller, HDi FMIC arrived at the office!!
come on nismo products from japan!
A busy night in the garage tonight? :P Pics to follow I hope!
haha busy indeed!
tell us if you notice a difference with HDi FMIC .. i actually noticed more lag in the short end because of the stock turbo. but pickup in the middle range top end when it was cold at night (bearing in mind qld winter is 25C)
hopefully that will change with the hiflow.
got some tuning nuts today and replaced the stocky nuts with all 20 of the tuning nuts.
Should be a good deterrent for anyone attempting to steal the rims as theyll need to get all 20 off without rounding the nut and that wont be easy.
and ordered the centrecaps from rays.. $200.. (rip job)
Can park out front without being overly paranoid now!
Edited by PetroDola
Are they the Taleb tyres ones?
I bought a set, finish was nice, but I ended up running at tap down them as the threads were fairly gritty. Check them before you fit them.
hi duncan , not sure what brand they are , i got my tyre friend to source them for me from mullins wheels in SA (the bag had no brand names), but they were really good nice threads and clean.
i needed quite small ones for the key not to scrape the rim as its really narrow
Edited by PetroDola
haha im not going to install till the brake rotors arrive, then ill do brakes and suspension at once to save wheel removal time
i wish i could have done it tonight, had photo comp to go to instead
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
