Well. maybe not today but.
HDI FMIC
slim line electric radiator fan
TurboSmart PB BOV(to be changed soon)
3.5" Dump pipe
Dump Back 3.5" exhaust
8000k Xenons
Greddy Informeter Touch
Ball Bearing Hi flowed Turbo(weeeEEEeeee)
Trans "lock up torque converter"
Trans reversed +/- for tiptronic
iPod compatible PA15-NIS install
Unfortunately it isn't tuned yet, just trying to put together the cash for;
plenum spacer kit(Cam)
Stock BOV
Trans Oil Cooler(Craig)
Walbro Fuel pump
650CC+ Injectors
eManage Ultimate
bigger suction pipe
and we shall see what I get out of this budonkadonk of a car :whistling:
I haven't done as much as others, but its a start right?
HDI FMIC
3.5" Dump pipe
8000k Xenons
Stock BOV
Walbro Fuel pump
650CC+ Injectors
eManage Ultimate
bigger suction pipe
and we shall see what I get out of this budonkadonk of a car :)
@Aaron is that Stage 1....lol! :D
@KV2 - thanks mate.....I cannot even remember writing that list :whistling: ....lucky the wife never found it :) .....ECU has changed now - NISMO/Emanage Ultimate(don't do Haltech) combo and 610cc injectors....motor's a bit broken ATM but should be back on the road later this week and then down for it's final tune!
@Aaron is that Stage 1....lol! :whistling:
Stage 1? what the turbo? i dont know he said something about gt30 fans or. its when i was new to the turbo. so he did it n i paid him lol
and what do you mean stage 1? arent you at stage negative 10 Mr Flinstone? hhaah joking
hey english conversion, gimme gimme
Front was 90mm off the ground. Too low!
I'm contemplating importing some Teins to fix the problem for good. I'm not sure how good the factory shocks are, but the C34's I've been told couldn't stand up to the punishment of 100,000K's + Don't know if the M35 is any different. My car has done 70,000K's, so might be a little life left in the old girl yet?
Mine had 39xxx kays when I bought it & my rear shocks were wallabyted! The fronts were not far behind...
You never know though...
can you do mine too mate? im happy to not pay you :(
It was literally a 20 minute job :D It's been driving me bezerk!
I'm happy to not have you not pay me to not do it? Not? :D
If you want some tape I can probably hook you up. Either that or Con-Tact adhesive backed felt is good for this too.
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
