anyone keen for and ARX, only $4000 at the moment
Im sure this is the car that is owned by a crash shop guy around the corner from my work. I see it every day at his crash shop as Im going to work, then a few weeks agoI seen it sitting there looking like this.
Well it must be an easy repair if a panel shop worker won't touch it...
Best kept... Yeah, except the smashed in front corner.
"Titanic; one of the best kept examples of 19th century ship building. Only crashed into one iceberg, superficial damage; easy repair..."
^^ LOL ^^
When he says "light damage' he must be referring to the actual head light being damaged (actually missing). The rest is more like "moderate damage" and I think more expensive to repair then he is making out.
lol..
nah seriously.
im starting to put money aside and maybe in 3 months might put this up for sale.
ive always wanted to get into a 32 R since i was small, have been looking at a few as of late, and im getting interested.
lol..
nah seriously.
I've been doing the same thing lately. Over here in W.A we don't get that many really nice examples so I've had my eye on this one, I love ths car!:
http://www.carsales.com.au/all-cars/private/details.aspx?R=10959085&__sid=12BA56AF125A&__Qpb=1&Cr=0&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&keywords=&__N=1216%201246%201247%201252%201282%204294963846%204294963593%20399%20447%20904&PriceFrom=399&PriceTo=447&seot=1&tsrc=allcarhome&__Nne=15&trecs=4&silo=1011
lucky bastard...wish I could get a 2 door car :glare:
lol your fault you couldnt keep it in your pants lol
http://www.carsales....ecs=4&silo=1011
yeh lol thats interesting.
but i want a faily stock one(if I can find it) dont wanna modify it or anything.
but just want one coz its the first car ive ever wanted.
Scotts already trying to talk me out of an RB lol :laugh:
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
