met a guy in coffs with a 7D, nice piece of kit
but the main thing about the nikon that i cant stand with the canon is the rear wheel.
my nikon has it opposite the front wheel, the canon has the large menu wheel as the activation for your 2nd function and it gets in the way of your face.
i had a canon before i had the nikon, so yes i can speak from experience :)
So... you're weird and you blame Canon? Should have just got used to it :P
I've got a 7D, only complaints are in terms of using it as a video camera.
Who puts HDMI out on a camera and doesn't let you stream full HD over it?! :domokun:
lol the 7D and 5D2 werent out when i got the D700, so i made a decsision as per the models available at the time.
i still think i made the right decision for me.
nothing is buried in menus, everything is right there and i can change them easily.
each to their own! i only like bagging the canon guys because its fun lol
Its only in the way of youre face if youre a left eye shooter, and even then - theres a 2nd wheel near the trigger button the the 5D and 7D that will do the same thing as the rear wheel 90% of the time. Im not sure whats hidden in 'menus' that youd want to access with the quickness.. Everything I want to fiddle with (Shutter speed, aperature, iso, AF method, metering, white balance, shooting mode) is on the Q screen which is pretty damn quick? Half the items I mentioned also have dedicated buttons on the 7D (AF, Iso, WB)
To say I think Ive made the right choice me would be accurate :P
yup im a left eye shooter! but im right handed. weird i know
90% of the time isnt good enough for me :P
then again i only have shutter and aperture on the wheels. nothing else needs adjusting.
cant compare the 5D2 and 7D with the D700 as their functionality was taken after people mentioned that common functions were buried in menus. which was why many people moved to the nikon pro-series.
however, yeah i have buttons for ISO, WB, focus mode, meter mode etc
just use a noise reduction program. sometimes they work well. i guess it comes down to how noisy your camera is at whatever ISO youre using.
get a 580ex speedlite, its got 200mm zoom (i think)
Yep, using Lightroom and it's doing a pretty good job, I just need to learn more about using it and Photoshop properly.
Ive seen Noise Ninja do some fairly amazing things. Smart software.
If Nick has a crop body & his lens was at 200mm then even the 580 wouldnt help - as he'd technically be at 320mm. Ive never shot with a monopod, but under those sort of circumstances it might work well..?
Yep, crop body - Canon 60D, and no, the flash wouldn't have helped over the distance I was shooting. And I own a monopod now, but didn't then.
And 'sif not real zoom - it's still optical zoom isn't it? So it IS real! :D
Dunc is right, Iain - you're just a weirdo! :P
The 60D has the screen and controls at the top near the shutter button too for quick access to ISO, AF mode, drive mode, aperture, etc. But the Q screen is an excellent idea by Canon in regards to seeing and changing your settings on the fly.
Off topic; how is your new toy Aaron?
a friend was helping me work on it, to get rid of the BOV and put a stock one back in.
I was trying to get the airbox to fit, but when he went to put the battery back in he had managed to short the terminals together.
positive wasnt connected, so it basically fried all the earths in the car. - since has been fixed..
it has also done something interesting to the Power FC. instead of resetting it, like it would usually do, it has thrown a bunch of random figures into the map.. especially the voltage autocorrect. when the voltage drops it adds the smallest amount of fuel.. since the short? its adding a f**k load of fuel and actually fouling the plugs and misfiring - so whenever i turn the headlight AC radio etc..
Sabbadin auto has fixed most of the problems, and changed some of the corrections in the PFC to allow me to drive it while getting it fixed but yeh.. needs a full retune.
blew up the AFM on it as well, happy that it was upgraded to a Z32, and theres a f**k load of them, so now I have 3 spares lol.
i found a couple of leaks that should cost about $50 to fix, and can do so myself..
but yeh. thats my current problem.. should be good in a week or so, depending on when I get off my ass and do it.
150psi across all cylinders..even with the big wade cams
he said overall its a good car.. so that pleased me..
Wow thats some bad luck you've both had with your new cars Aaron! Fingers crossed it gets sorted soon
yeh if the terminals didnt short out. everything wouldve been fine
Common denominator? :P
Aaron has, at one point or another, worked on both of them? no such thing as coincidences.. whistling.gif
Whose going to do the tune? Same place that did it last time or can Cihan tune pfc's?
i'll let that one slide.
Cihan can tune PFC's but a very hard person to get hold of.. plus everyone can tune a PFC and Chequred tuning(trent) is 10 minutes from me. Chasers is near my work.. and Sabbadin the Mechanic/tuner working on my car is also reletively close. cant justify driving to whoop whoop, when everyone else can do it, and do an amazing job too..
i dont want to get the person who tuned it last to re do it, as i couldnt trust him more than a wasp on my hand..
Sounds like a plan then! I wish there was a tuner that lived 10mins from me, all the ones in adelaide are at in whoop whoop [for me at least] :P (irrespective of what sort of aftermarket ecu you're running!)
previous tuner wasnt the builder.
according to sabbadin, the build is amazing. had the head off and went over everything. tuner on the other hand.. havent really heard anything good. so yeh wanted to get it retune anyway.. just didnt want it all to happen at once.
edit
built by http://www.engineaction.com/
Edited by Sunkist
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
