Big big wet has come to the southeast Everyone safe? Evacuated, or flooded?
Nice....but it won't go with aaalllll the other bits I have coming! Plus that's not part of the widebody Nismo kit! ;p
Takero's (?) front bar Craig - surely that will match some of the bits coming? Just needs paint..... :whistling:
yummy
i'd be happy with just a front lip & side skirts...
contemplating whether i should get the skirts for sale on ebay
There's more then one nismo kit for our cars?
I thought this one was it?
Nope, just one Nismo kit for NM's and one for PM's.
They are only "widebody" if you modify them to be and are made for RS/RX's only
Yes
mmmm.... Takero's ricey goodness
Interesting...got a pic?
Yes
concur...bit OTT riceness...
Damn you!
Don't won't front bar but the back looks like porn IMO!
1331192222[/url]' post='6266681']
Ahh, just heaps of awesome wagon action; hard to explain, coupe owners wouldn't understand...nyaanyaa.gif
Haha same old shit.. Given up on cars for the time being so just driving around the Jaffa
1331208343[/url]' post='6267141']
No gay s14 shit bro from another mo!
We have the speed and handling...just working on aero!
2 tonne of our of control goodness!
haha I hear your getting a wide body? I thought stags already have that
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
