Engine out.
Whats a Evo engine worth? That should be your track car TBH, but this:
I don't know mate, perhaps 3k?
I could buy the forged parts to rebuild it for similar coin I think...
I don't know much about the evotards, how much is said stroker kit Dale? What are my options? Looks like I have a bit of research to do...
Edit... http://www.amsperformance.com/cart/AMS-Mitsubishi-Lancer-Evolution-Evo-4-5-6-7-8-9-Stroker-Kit.html
Cheap... :)
Edit... http://www.amsperfor...troker-Kit.html
Cheap... :)
Lol; very cheap.
I think the Tomei 2.4 is around the same, a bit of a no brainer to bump the capacity if it's apart...
I might buy a wrecker motor to get it on the road, then rebuild this one myself. Can't be too hard can it? Only 4 cylinders. :)
No cam chains either; piece of piss to put together.
Invidia do a full stainless dump to tip exhaust for $1500. Cast stainless dump, and a 100cpi cat. Nice quality too.
Better have enough for two lol.
Also need to do the LICP(lower intercooler pipe)
I'm happy for you two to be "connecting" with cars again but Aaron, that has to be the lamest abbreviation... not to mention that you had to explain it thus negating the need for an abbreviation.
It is what it is, mang!
Did you know what an LICP was prior to reading what the abbreviation was? I doubt it.
Yu gay boi
Yu gay boi
Haha, I didn't know what that abbreviation was because I don't wear my hat backwards, wear gheyboi skinny pants and buy a bright orange S14 and then an Evo "because YOLO" like some.
You Mitsubishi owners are all the same...
:ph34r:
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
