Friggin sweet shots guys :(
Sidd - I can tell right now that your logo is like that because its an image on a white background and your just copying and pasting it on and your marquee selection is getting free transformed or something?
1. Open the image with your logo on it.
2. Copy it to a new layer - MAKE SURE ITS TRANSPARENT
3. Make it however you want.
4. Save it as a PNG (there will be no background, only the logo).
5. Should be fixed!
Maikul - It works by taking a long exposure, painting the car with a light source and as long as you move fast enough you wont ghost in the photo.
  • Replies 317
Posted Images
If you were subscribed to my blog you woulda seen them already :blink:
But here ya go. I'll post more of the extreme shots later on, i was too tired and just wanted to get project 365 out of the way. But fcuk me suspension is amazing. Nearly rolled twice as well, it was awesome! I Was in the blue hilux. Had about 200kg+ in the boot full of gear plus the roof car tent.
My mate in the silver hilux, fell straight into a hole in a river crossing and almost rolled, got stuck, took us 2 hrs to get him out and cutting down of tree's and getting extremely saturated and muddy!
All this = Awesome weekend.
^ WOW CRAZY!!!!
Your friends hilux kory?
btw i have subcribed to your blog, but no email yet. I normally get it around 11am or so. Check your feedburner settings. You can change the time the email comes. Im sure you know that already.
Edited by siddr20
Yep, i set it at 11 so if i need to change things the next morning its alright hahaha. But i might make it earlier. Cheers!
Yeah my mates hilux. They are all tree-loppers so if tracks were blocked/too narrow.... Out came the chaninsaws and timmmbbeerrrrrrrrrrrrrrr!
Also with the light painting, make sure you are between the camera and the light source, or you'll pop up as a 'ghost' if you stop moving.
where's some of these 4x4 shots? ;o
Ah okay, very cool. Will have to give it a try sometime.
That's pretty clear man. that's using a tube and not a dedicated lens yeah?
I shot a couple buildings in the city over the weekend jay, I'll post one up later on :P
did you do a bunny hop to get to the 10th story? haha :D Post a pic of your bike.
24-75 f2.8 with a digital extension tube... which is kinda handy cos the camera can still do auto ISO etc. Tube knocks it down one f stop though, so can't use it with slow lenses.
http://www.digitalcamerawarehouse.com.au/prod6897.htm
still gotta use manual focus for best results.
Thanks Zennon, more to come tonight :)
Like that shot of your dog funkymonkey!
Nice night drifting shots. I like 'em!
And jay - I want a photo of your bike too! With LED light painting around it :P
oops, double post. :P
spotted this awesome looking Elgrand on the way home. It's an E51 model and not sure what rims it was wearing, but damn it looked nice. This was my attempt at a rolling shot, lol.
Day 020: 2010-11-09 by jay019, on Flickr
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
