... surely you can rip the parts off the wreck to put onto the new beast?
...what I was thinking after CRD and you made some serious mods.
...and a convertible might not be a bad idea either, upon buying back the wreck.
i reckon thats fix able, just cut the roof off and weld have a new one welded on, new rear window and any other bits that got broke, and re spray it. what auctions is it going to?
Well from the pics you can see turret, both rear fenders (looks like damage to both rear pillars), rear screen, headlining and rear spoiler. Those parts alone exceed $10k. Then there's any parts you can't see in the pics which i'm sure there would be. Add to that the cost of labour and you can start to see why it has been written off.
also don't forget you can no longer re-register 'repairable' write offs in nsw any more. :/ too many fkers using the scheme to re-birth stolen cars as opposed to poor mechanics who bought financial write offs and repaired them nicely in the hope of making an honest buck.
Heres what the R34 looks like with the roof off!
Wonder what the R35 would look like?
Shame about that car, at least you are now getting the BEST colour!
Heres ya go, a pic of the R35 with no roof
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
