Tomei “cooling channel” are over 3k landed (RRP)
Normal Tomei are around 1800 landed (RRP)
Wiseco or CP (as an example) that come in around 1k-1.2k landed (RRP)
Tell me then please - what exactly do you get for 50% more cost (Tomei standard issue vs Wiseco/CP)?
Just reduced piston slap because of slightly different composition? Come on… Hardly a deal breaker.
Looks to be nothing drastic either way – as I cannot find a detailed spec sheet which would have me believe it’s probably not a lot different to most other pistson on the market, that for which, you can find detailed spec sheets.
Tomei ones don’t magically support another 1000hp, are any less prone to failure or anything else.
If the only thing they can claim is reduce piston movement in the bore due to their composition, then that honestly is not a deal breaker at all when you can have a motor built tight enough these days that piston slap isn’t really an issue.
I'm all for buying the best parts, but you must be mindful of a budget - and this guy is working to a very tight budget. An extra $600 or so when its simply not required, doesn't help him at all.
Just read this for difference in characteristics
http://www.tomei-p.co.jp/_2003web-catalogu...iston_rset.html
a smaller search and you may find more info.
as for his budget, he hasnt actually stated one has he? so its just another one of your assumptions? i know for a fact he was looking for tomei pistons but couldnt find any that were a std 86mm (we work in the same workshop)
Have you actually built an engine yourself with tomei pistons? or have you delt with them personally? or is your budget 'too tight?'
Characteristics? I want hard specifications. Not some marketing mumbo jumbo.
There is hardly an iota of specifications. Doesn't even tell you how heavy the piston is for gods sake.
I've had 3 motors (2 26's, one 25) with the apparently inferior pistons - Not one has made any noise on start up.
All motors have made 350rwkw+ without a problem, 15,000-20,000kms and compression is fine. Good enough for me, and good enough for the vast majority of users here and around the world.
My budgets generally are not tight, I just refuse to waste money on exotic brand name Jap stuff that offers no discernible advantage over another product local or US etc other than to lighten my wallet unnecessarily.
Guys why bother?
This "build" is so budget. Put new stock pistons in and be done with it
Not even.
Just buy a second hand 25 and slap it in. It will be better than your hand built 25 anyday. Genuine Nissan built ftw.
You cant just be a noob and build a RB by 'specs'. You gotta know the tricks.
Although I guess it is cool to say you built your own forged 25 for an awesome 300hp. Not really actually. Its a complete waste of time.
lol, i didnt mean to start a shit fight. but for me this build is far from pointless, the budget is very tight arse, yes i admit that but the amount i can learn from building a motor myself is far from "pointless" to me and who's to say the second hand "low km" motor isnt just going to shit its self in another 10,20>30,000km's? and put me back to square one? sure it may not happen but i'd prefer to have the reassurance that the motor under my bonnet is built by me so i know everythings right with it.
That's the point Femno was making :D
Who's to say because you built it, that it wont fall apart in 10k --> 30k kms?
The fact you want next to no power, have a ridiculously tight budget - its really not making any sense at all.
The 2nd hand motor makes more and more sense with each post you make
Regardless of anything. He can do whatever he wants. If he wants to waste a build to learn from it then kudos to him. However I would just do it as std recondition so you can follow the manual. Unless you know better, then go for gold.
I cant find the other thread at the moment which has all the people who have built custom engines and only had them last 10-30,000kms. I would put more faith in a second hand factory engine then a custom built engine at your power levels. The ultimate would be a factory rebuild I think.
Agreed, see my thread where I asked how long motors last and who's had a motor grenade before 5,000kms, there was a reasonable number of people, something around 10-20% and I HIGHLY doubt that that many second hand motors grenade.
dude, go the import wreckers fit a Neo engine and be done with it, for your wishes a std neo engine will be happy for about the life of your ownership. building an engine is a waste of time, the neo head will allow nice cams without the big expense of springs and so forth
will save you a fortune...
One of the reasons ive gone with tomei pistons, is cause ive taken my time to really research thousands of forum threads, not only on skyaus but others worldwide.
What i found is people who have had engine rebuilds (with the said cheaper pistons) have had them fail within 30,000kms of a rebuild, and thats from being built in fairly reputable workshops all over the world (also stated on a thread on skyaus).
This is due to various reasons, one of them being pistons slap (even if it cant be heard with the naked ear) and it eventually turning your bores from being circular to more oval in shape. This is caused by the piston rocking on its pin as it goes up and down the cylinder (when cold). Have also found out its to do with the metal expansion rate being too large in some of these said pistons. Having a larger piston to bore clearance is what the manufacturer has put in place to try compensate this. Thats fine once the engine is at normal operating temp, but very disasterous when the engine is still cold.
I actually had this happen to a friend of mine. He had a fresh set of (not going to name the pistons) put into is rb26. After 10,000kms piston slap became audible. 15,000kms later ridiculous amounts of blowby. He had his engine builder (fairly repitable workshop here in perth that i will not name) who actually built his engine in the first place strip it down. What he found was excessive wear on the thrust faces of his bores due to piston slap. The engine builder then stated to him that most of the cheaper pistons will do this due to thermal expansion rates of the cheaper styled pistons, and also said it was not the first case of this happening. He also recommended tomei pistons to him and explained the benefits of them too him, so they where indeed fitted.
80,000kms after a set of tomei pistons and a brand new n1 block (block was totaled by previous pistons) and the car hasnt missed a beat. That is also another prime reason i chose tomei pistons. Im not goin to preach to anyone anymore. What im trying to say is do your homework before you get stuck into your build, it will save you a load of money even if it costs a little more! :P
If no one can post the expansion rates of the tomei pistons and compare them to other reputable brands then I don't think anyone is going to take this that seriously, if you can't hear the piston slap there is no way in hell they are going to fail due to it in 30,000kms
not to mention there are plenty of audible slapping pistons that last >100,000kms
ive heard of lots of failed builds but none due to piston slap.
If CP's, JE, Mahles, Ross, Probe etc etc were so bad, would they be used in 1000+hp Prostock motors, 1000+hp blown street motors etc etc?
I cant say i have seen an engine fail due to a bit of slap when stone cold...if they were slapping when warm then the machinist/engien builder has f**ked it not the piston.
But would you have 1000hp blown street engine racking up the kms as a daily driver? And of course your gonna want things looser in a 1000hp motor! Like you said i think its about time we gave it a rest and go back on topic perhaps?
+1
Remember that is just one engine builders advice. Whats to say he didnt setup the engine with the Tomei pistons differently and blame the cheaper pistons??
At least have a chat to a few other engine builders and get their opinions.
But if you have already decided and willing to go against everyone here then just do it.
+1
Thats what im trying to get at here. Tomei states to setup the engine differently to suit these pistons, so of course its been setup differently.
Thats just one engine builders advice that has been dealt with personally. The list would be too long of other reports stated on other forums. But yeah like you said im not going against anyone. This is just my opinion on this.
80,000kms after a set of tomei pistons and a brand new n1 block (block was totaled by previous pistons) and the car hasnt missed a beat. That is also another prime reason i chose tomei pistons. Im not goin to preach to anyone anymore. What im trying to say is do your homework before you get stuck into your build, it will save you a load of money even if it costs a little more! :)
Not sure but i think they are made by cosworth, and yes they are generally better (i have run greddy pistons in about 7 engines (SR's and RB's) now) than the run of the mill probe, mahle, CP, JE etc but the reason they are generally better is they come out of the box with killer ring sets better crown profiles and base stock but as for life there is not much in it if it is built properly.... we get the same life out of JE's (our most used brand)... wear on the thrust side and audible slap @ 10,000km was a builder issue not a piston issue.
The greddy pistons (again i think cosworth due to very odd ring sizes) are generally quieter and run finer tolerances as the base stock is better but @ up to triple the price you could do another engine for what you saved... I use them only on high end builds and my own stuff.
Tomei's are made in there own warehouse as with all there items, they too have very wierd rings, there quite alot smaller?
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
