I have ditched the skyline for a while and have got the mini. The plates and rego sticker arrived for it today. How funny is it to drive! Might take to the next Mountain run and show a few skylines how to take the twisties, what do you reckon? Pity I would be half an hour behind after the up hill section!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Shitta cruise huh sound like an idea. Looks like I will be turning up on Thursday (extra work has been put off for a little while, I might just bring the mini for a strap for something different. Don't forget the GT minis standard performance features strutto: 1275cc, extractors, 1.75" exhaust, twin 1.25" SU carbies and wait for it, front disc brakes! Plus a tyre upgrade, Yokohama A008s measuring a huge 165/70 R10!
Its funny how things change, I always thought the mini went alright, but now (apart from its cornering ability) performance is, well, kinda lacking.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
