Just finished washing the mini and the skyline just so I could spend most of the time standing under the hose. Was good while it lasted, might be a bit of a storm coming though, that might cool it down a bit. Time for another cold shower I think.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Was just at Dicky Beach, Lifeguards came over the loud speaker "theres a severe storm warning" everybody leaves likes a cyclones about to hit!
10 mins later, the same warning but with "hail warning", oh shit me grabs the missus and runs to the line and an awaitng vacant garage.
90 minutes later, not a drop... Ahhhh!
heya lauren, nice name, got a cousin with the same name.
Im Caillan, :headspin:
nothing to do eh?
i was watching the lightning, but its moved over now :)
was perfect photo time too cos it wasnt raining just lightning,
didnt get any shots bcos my dad took the digital camera overseas
Oh and was watcing a special on tigers
hmm one of my favorite things.. Tigers and Storms :)
just came home from the pub ... had a really good night :)
you guys are having some pretty weird weather over there at moment ..... then again so are we .... unfortunately havent had the lightning yet :)
you work tommorrow?
Cool, im hoping to get into my carreer early. Alot of people these days waste too much time working part time for money and dont look at the big picture
Getting some minor repairs, new headlights and rear bar etc
Will look nice, look for the pictures in a few weeks time
Great talking to you Lauren :)
I gotta get up at 8 so im off ta bed.
Have a great nite!
Cya! :headspin:
Yep computers don't like heat.
The large amount of suposedly faulty computers I have seen in the last few days, have been from people trying to use them in an un-airconditioned offices or at home in temperatures close to fifty degrees (90 degrees inside the tower) and then wondering why their computer was shutting down by itself.
Heat is the mortal enemy of all electrical equipment.
My computer ran all weekend constantly ..... What a machine :D
My car on the other hand did 800k's so we could sit in the airconditioned comfort :D
*phew* lost this thread for a moment.. thought it might have been deleted :D
yeah, my computer is holding up.. my car too :D even better. Computers are cheap these days fortunately, and power supplies, etc can be replaced for a few bucks. Saturday i did 200km in 41 degree or so heat.. giving it quite a bit of stick with darrin and strutto on the highways. Still holds a bit of power. Go the intercooler!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
