as stated, im getting my 3 piece enkei RS Evolutions Rebuilt, and the front 2 are getting new outer barrel.
color will be full matte black bolts will be gold
so on the front i will be sitting 17x9 and the rears will be 17x10
originally the 17x9 were on the rear and 17x8 on the front
so front getting an extra 2 inches and popping them straight onto the rear.
guards will be getting pulled by about 1-2cm to try and fit in the rims.
i will be hoping the rears will be sticking out an inch at least, and front will be nice and flush.
currently running 215 45 17's for the 9j rims and still tossing up on what i should run the 10j's on, its either going to be 225's or 235's
what would you guys suggest?
and all up incl tyres will cost me around the $900 mark
p.s these are the real enkei rs's not the fake ones.
they will go on my s2 stagea
hmmmm, never thought about the satin, may actually invest in that, iva always had matte black, from my pc case to my older cars and car parts.
i shall see how much extra that may be.
depending on how much you flare the guards, I would say go with the 235's on the 10j rears. My brother has gram lights 57 pro's 18x10 +12 all round on his s15 and the tyres are stretched, but not over the top stretched (it looks really good)
few pics (from his phone so apologise for quality/size)
post-76525-1289348688_thumb.jpg, post-76525-1289348713_thumb.jpg, post-76525-1289348750_thumb.jpg
definately go satin black.... my te37's r satin and they r awesome lol.
ill get some pics soon, cars a lil broken in the garage atm :whistling:
also i run 245's or 255s on the rear of mine and 235's up front and thats on 9.5's all around.
Edited by GUN_METAL_GTR32
hmmm, those gold ones tm7gtr posted up, are close to the same dish as mine, pretty nice, i guess ill go with 235, seems to be a nice stretch. will be getting the cheap crap tyres though, kumho ecstas k31 i think they were, they are very soft and burn rubber really fast. but therefore grip is superb.
dont know if the offset will be changed, since its still the same distance from the inner dish as before.
Edited by Bronx
offset will change (for the better) as the midpoint of the wheel width will move outward roughly half of the increase in width overall while the hub stays stationary. brake clearance will stay the same
changing the outer lip on 3 piece wheels wont change caliper clearance at all.
yeah, i get that lol
was more asking just incase he had different faces on the fronts and rears.
my first set of professors couldn't be swapped due to differing faces.
oh yeah, ive never really gotten the whole offset thing really, but either way, i still need the spacers to clear my suspension :D but only on the rear.
did you need spacer before getting them widened... If not, i suggest putt the outer rim that is currently on the rear on front and putting new widened lip on the rear...
Double handling you say, well think about it...
You wont need to add spacers as the inner rims and wheel faces will remain the same just widening front and rear outer rims only...
Most staggered sets of wheels have different inner wheel widths and different brake clearances on front and rear faces for brake clearance.
And yes offsets will change and because your widening they will go from a high offset to a lower offset as you are increasing the outer rim width and by doing that changing distance from centreline to hubmount plane.
offset is the difference between the hubmounting surface (plane) with respect to the midpoint (centreline) of the wheel width centre.
+ve offset if its closer to the outer ie less dish or sit under guard
-ve offset if its closer to the inner ie more dish or closer to body or sit outside guard
anyway this pic should explain
Also if you domt mind me asking, whos spinning up these new barrels (outer rims) for ya...
I can only think of 2 mobs,
one ive dealt perfectly with, the other is a c*%^ that just doesnt wanna do odd jobs such as widening
paid him 50% pf his quote, he said 4wks then pay balance on pickup
only 14wks later i had to force them to give my wheels & money back cos he hadnt even started yet...
PM me as the above was at least 3.5-4.5yrs ago
and i need to go down this path again with 2 other sets of wheels...
    • Yeah they charge a little extra for mods , last year I noted no mods but I did have an exhaust fitted after that so  better to let them know cause these kinds of things can cause the policy to be void if you ever need to claim.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
