as stated, im getting my 3 piece enkei RS Evolutions Rebuilt, and the front 2 are getting new outer barrel.
color will be full matte black bolts will be gold
so on the front i will be sitting 17x9 and the rears will be 17x10
originally the 17x9 were on the rear and 17x8 on the front
so front getting an extra 2 inches and popping them straight onto the rear.
guards will be getting pulled by about 1-2cm to try and fit in the rims.
i will be hoping the rears will be sticking out an inch at least, and front will be nice and flush.
currently running 215 45 17's for the 9j rims and still tossing up on what i should run the 10j's on, its either going to be 225's or 235's
what would you guys suggest?
and all up incl tyres will cost me around the $900 mark
p.s these are the real enkei rs's not the fake ones.
they will go on my s2 stagea
hmmmm, never thought about the satin, may actually invest in that, iva always had matte black, from my pc case to my older cars and car parts.
i shall see how much extra that may be.
depending on how much you flare the guards, I would say go with the 235's on the 10j rears. My brother has gram lights 57 pro's 18x10 +12 all round on his s15 and the tyres are stretched, but not over the top stretched (it looks really good)
few pics (from his phone so apologise for quality/size)
post-76525-1289348688_thumb.jpg, post-76525-1289348713_thumb.jpg, post-76525-1289348750_thumb.jpg
definately go satin black.... my te37's r satin and they r awesome lol.
ill get some pics soon, cars a lil broken in the garage atm :whistling:
also i run 245's or 255s on the rear of mine and 235's up front and thats on 9.5's all around.
Edited by GUN_METAL_GTR32
hmmm, those gold ones tm7gtr posted up, are close to the same dish as mine, pretty nice, i guess ill go with 235, seems to be a nice stretch. will be getting the cheap crap tyres though, kumho ecstas k31 i think they were, they are very soft and burn rubber really fast. but therefore grip is superb.
dont know if the offset will be changed, since its still the same distance from the inner dish as before.
Edited by Bronx
offset will change (for the better) as the midpoint of the wheel width will move outward roughly half of the increase in width overall while the hub stays stationary. brake clearance will stay the same
changing the outer lip on 3 piece wheels wont change caliper clearance at all.
yeah, i get that lol
was more asking just incase he had different faces on the fronts and rears.
my first set of professors couldn't be swapped due to differing faces.
oh yeah, ive never really gotten the whole offset thing really, but either way, i still need the spacers to clear my suspension :D but only on the rear.
did you need spacer before getting them widened... If not, i suggest putt the outer rim that is currently on the rear on front and putting new widened lip on the rear...
Double handling you say, well think about it...
You wont need to add spacers as the inner rims and wheel faces will remain the same just widening front and rear outer rims only...
Most staggered sets of wheels have different inner wheel widths and different brake clearances on front and rear faces for brake clearance.
And yes offsets will change and because your widening they will go from a high offset to a lower offset as you are increasing the outer rim width and by doing that changing distance from centreline to hubmount plane.
offset is the difference between the hubmounting surface (plane) with respect to the midpoint (centreline) of the wheel width centre.
+ve offset if its closer to the outer ie less dish or sit under guard
-ve offset if its closer to the inner ie more dish or closer to body or sit outside guard
anyway this pic should explain
Also if you domt mind me asking, whos spinning up these new barrels (outer rims) for ya...
I can only think of 2 mobs,
one ive dealt perfectly with, the other is a c*%^ that just doesnt wanna do odd jobs such as widening
paid him 50% pf his quote, he said 4wks then pay balance on pickup
only 14wks later i had to force them to give my wheels & money back cos he hadnt even started yet...
PM me as the above was at least 3.5-4.5yrs ago
and i need to go down this path again with 2 other sets of wheels...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
