Sorry Bob, what I meant to say was "is $45k the starting price to get into an ADM from here on in"
The black WA car is still up for sale for $44,995.
Price drop........
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-176916&Cr=2
Bob.
That black car on Carsales.com.au in WA is originally a jet silver coloured car as per KG1 code on the compliance plate.
That's sad......
A collector won't touch it with a barge pole and an enthusiast will buy a nice JDM for half the money.
I sincerely wish the seller all the best but I just can't fathom who would buy it?
Bob.
Yep thats been for sale for a while. I ampretty sure I saw it for sale for a lot less on this forum a few years ago.
Different colour
Different seat material
and different engine block
There is no way anyone would pay a premium for that car.
That's sad......
Bob.
Well the car would still be a better buy than a JDM if u wanted certainty around service history.
You could easily respray it back to silver.
With regards to the engine number, what are the rules around buying a blank block from nissan and restamping it with the original numbers? I think if the original engine number was not reported stolen or registered = feasible solution for the right enthusiast.
This is all based on buying the car at the right price.
Absolutely. You only have to see how much people have paid for rusted out falcons with the right VIN#. Collector world is kind of a parallel universe.
New blocks from Nissan come without an engine number, you are expected to stamp the original number onto it when you install it. In any case Nissan (including FAST) does not provide a link between engine number and vin# so you cannot prove a claim that an engine is or is not original.
Just an update on mine. Still for sale with 'offers' put on the add. I have had interest.Nothing progressing to people actually coming to look at the car. With regards to restoring one, it can become really expensive. If you can't do most of the work yourself, accept my words of wisdom and don't buy one that needs major restoration. I also have (for those that are old enough to know) a Valiant VH E55 Charger that needs restoration and was quoted 80 grand (turn key) by a popular Mopar shop in sydney. A guy i know, can do it as a roller for 20 grand. You still need to do the drive train and chase other parts that may be hard to get. It adds up..
Edited by bBlack
Hi All,
I was going through some old photos and came across the attached R32 GTR ADM.
It appears to be a Promo car for Recaro and was displayed at the 1993 Melbourne Motor Show and is dark green in colour. It looks standard on the outside apart from the aftermarket wheels and repaint.
The ADM features are there, roof mounted aerial, tail lights etc.
I wonder if it survived??
ADM GTR32 GTR Recaro Promo Car Mar 1993 Melbourne Motor Show.pdf
The silver one for $30,000 is being sold by Andrew @ hyperdrive Motorsport . I don't think it's advertised anywhere as such.
That Silver one has since been Sold.... as I asked Andrew about it.
I've seen this car featured in a few of my old car magazines. Bob.
Thanks Bob, I took those pictures back in 1993 (when some of the guys on here were not even born), with a real camera that you had to go the shop to get the film developed.
I was very much interested in these cars back then, even though I was a Holden fan and drove my V8 around everywhere. BTW, I still have the V8 (garaged and covered).
Perhaps, this "RECARO" GTR can be also added to the list under "others" or similar as it is now Green and doesn't fall into one of the 3 colours available.
Regards,
Tony
Here you go Tony..........
I just scanned this out of Australian Road and Track Feb 1993.
It was featured in a couple more mags but I just don't have time to find them all.
Hmmmmmm Attachments dont work?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
