Hello everyone, i am going to be selling my ADM R32 GTR (Chassis No 6F4KBNR32A0016028) in the next week or two so thought i would let you's know first before advertising elsewhere. Car is all original and is silver build number 17 - 100 i shall update with photo's and details over the weekend.
  • Like 1
20 minutes ago, RB26DETT 240Z said:
Hi Robert, its Cuong with the black ADM gtr, I've sent you a PM
A black ADM next to a silver ADM would look nice in the garage :) oops I just realised you didn't pm the owner of the silver ADM
Edited by Marko R1
Error
Hello all again here are the details of the beast
Colour : Jet Silver KG1
Delivered : May 1991
Sold : 05/10/1992
Number : 16 of 100 ( 016028 )
Kms : 261 750 ( Service History, Log Books and Receipts )
Dealership : Westpoint Nissan Qld
Owners : ??? Maybe the 4th
Purchased : 30/04/2013
Located : Perth Western Australia
The car is all original condition with no modifications and has all service history, log books, receipts, spare key, touch up paint ( unopened ) and do have items that I have collected over the the 4 years that will be sold with the car also. If you have any questions feel free to call and ask away and I can be contacted on 0423 549 665 Robert.
Car is located in Perth Western Australia
Asking price $ 42,000 ( Custom number sold with car )
P.S Have had difficulties uploading photo's so shall try again in the next couple of days
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
