Yeah, I am very interested to see how it goes!  Obviously this is all theory, and I think there is worth in the thought experiment side of things.
If you haven't checked them, here's the turbine flow map for the normal GT35 turbine (ie, like from your 3586HTA)
And for the "RS" version:
By Garrett's own admission/claims the increase in flow "A/R for A/R" the new RS turbine is only margainally better flowing than the existing GT35.  On paper the 1.06a/r GT35 housing will actually outflow the 1.01a/r "RS" turbine though obviously there is more to it than just that.
Edited by Lithium
Not interested in the GTX3582R GEN II, given the turbine is the same as what I've already got.
How much power does the GTW3884 produce with the 67mm-84mm comp wheel?
I think you missed the point of what I shared.... the difference in turbine flow between the old GT35 and the "RS" one used on the GTX3584RS is 2/10ths of f-all.
Based off what is available on paper I would wager than the GTW3884R will make more power than the GTX3584RS but will obviously come at some cost in terms of lag but I don't know what people have actually made from the GTW3884R.  I'm guessing something close to what people used to make with GT3794HTAs
Comparing exhaust flow between the GT35 and RS turbines at the same housing size there is a difference in flow. Okay it's not huge, about 1.5-2lbs/min at the important PR range of 3.0-3.5 where most RB motors will operate. Of course anyone willing to sacrifice even more response can use the 1.21 housing where the increase in flow over the GT35 is closer to 4-5lbs/min.
If I can get around up around 530-560kW at the wheels and peak boost by 4000-4500RPM or thereabouts I'll be more than happy with the decision.
Found a dyno result for a GTW3884 on a BA XR6T. No other details other than just over 500kW @ 25psi.
GTX35_TurbineMap.jpg&key=d1b86af86e594e8efdf3cee3ab44ab98bc5358f9501e4bedc092d544667fbd1c
GEN2GTX3584RS_TurbineMap.jpg&key=35a4320fb2bb48eda32282d583c64fe1572fd98d945576510c52bbd8b489e913
1.06 vs 1.01 isn't A/R for A/R [emoji6]
Three more XR6T with GTW3884R results:
427kW 21-22psi on 98
423kW on 19psi also running pump 98
490kW on 24psi Unknown fuel - possibly 98.
Found a 512kW on 20psi running E85 but not sure if it's a GTW3884 result or not
last one i saw was 655rwhp on 36psi through a auto sohc rb30, 144mph ish traps at 1300kg ish
What you and your mate are missing matt, is you are talking T3 housings, doesnt matter how good the turbine is..your pushing shit uphill
from 450rwkw onwards really on a 3.0...okay on a 2.0.. its t4 time if your starting from a clean sheet of paper..this will never change
your giving up spool..and power
Out of interest..the p trim turbine is hardly anymore efficient than a 3582 turbine in the real world without  being backcut alot
and the 65mm old precision turbo turbine is a turbonetics f1 wheel
Edited by jet_r31
So if the T3 housing is the limiting factor, how have people managed to run over 170mph trap speeds and the horsepower required to do so using a T3 housing?
And vls have run that close to that with 3582's with the KTS 11 blade gtx billet wheel on less boost..
my mate went 140mph on 30psi with stupid retard  backpressure(full exhaust  with gate plumbed back), others have gone 143 on 32psi.. with .82s and backcut 3582 turbines
I wonder what peak power gain I would see switching from the current FP T3 0.85 to a Garrett 1.06
463.7kW @ 25psi was all we could get using the 0.85
Saw another RB30ET make 450kW through a 2sp glide running a GTX3582 GEN I - roughly 480-490kW through a 5sp on the BW dyno
Yeh my mates vl made 450rwkw though glide on 30psi with just that 67mm comp wheel upgrade on 3582 ..went 140mph
make f**kloads more with exhaust off...but went straight to 40psi...and maxed out 2 044's
laggy though...
you really want a pt6466 .82 t3..
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
