The bit they had on the new Tires was interesting after a conversation i had with some Michelin big wigs last week.
When all the suppliers placed their interest Michelin pulled out when told that F1 wanted a tire that would "go off quicker" as it goes against Michelins philosophy of endurance and "economy".
There has already been some comments that the team cannot talk about the falloff due to the Pirelli being unhappy with the negative media already
Also noticed that One has Ferrari listed as "Scuderia Ferrari Malboro"
really? wow thats a bit risque!! hadnt noticed but wll look next time.
i like the idea of trashing tyres easier. makes for smoother racing. and yet the wing (which i can still see failing spectacularly) and the Kers should add the speed back into it.
Vetools time was with the wing up as much as possible and kers in use....neither of which they had last yr at this point.
woot Q1...envious of those that are there. thinking of making it our honey moon next yr. perfect timing.
Edited by boiracer
Its on the 1HD timing not the BBC one, so when they had a run down of the prac sessions pre qualifying
:unsure: Heidfeld out in 1st Qualifying session!!!
agreed. that was awesome. and lucky.
Kobayashi neeeds another drive somewhere. that was a champion effort. dam that little guy can drive!(although sauber does look alot stronger this yr already)
Edited by boiracer
Did you notice webs having a look @ the bottom of vetel's car when they were parking up after the last qualy?
koby was dammed impressive and it seems like someone lit a fire under sutil finally, dammed hot drive and one hell of a save, was thinking I'm about to watch sutil's death when he spun. sauber look hot this season.
torro in q3, holy shit.
what about massa baby, shit we area about to get eliminated, here's pull 2-4 seconds out of your ass with like 3/4 the lap done. that shit was insane.
vetel's time better than pole last season, Hol-ly f***.
Two things just happenend:
1. Either vettel is a finger wagging genius, or webber is jut as utterly useless as i thought
2. Vettel is going to go back to back. He may not even break a sweat to do it
And mclaren and ferrari are the wrong way around? where the hell did that come from louie!?! Nando will be dissappointed losing out by 1.4secs from pole.
So the bulls werent using kers, and apparently they arent saying why. Leading one to believe theres a potential issue
If for whatever reason they dont have this sorted by tomorrow, expect lewis and jense to absolutely mob them from the line
which would be a shame for vettel after that great performance
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
