lol. Certainly not the best driver, but he is a damn sight better than the majority of the F1 field.
How do you figure, over the past year he has been regularly beaten by his significantly younger and less experienced team-mate, which is the only person who you can easily compare him to.
He's come back into the sport to wrestle with people like Alguersuari while Rosberg nips off ahead (of the 17 times they've both finished Rosberg's been ahead 12 of them).
Maybe he's better than some of the newer drivers but he's not exactly scaring people with his limitless talent (well he did scare Barrichello in Hungary last year).
And they can get away with it too, so long as Vettel is in a better position at the time.
however, as they have shown in the past, if they pull that sort of business whilst webber is in a better or equal position.
world press will come down on the them hard... again lol.
It was a racing incident, happens to many cars every race, and both driver had to pit as a result anyways, which would have cost them most of the 20s anyways. FIA sometimes go overboard.
But wasn't hamilton the one who made more than one defensive move? That warrants a penalty, but misjudging the width of front wing trying to overtake someone breaking the rules at 300+ km/h isn't exactly a malicious act.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
