i spread the funds around a little this weekend then. the macs surprised me a little last weekend
30 on seb, 5 on button and 5 on the flying russian.. prob should put lewis on there too if its wet he wont waste tyres..
i hope they fixed their kers gremelins.. will have to watch fp1-3 and see how they are looking.
I was at this race and one thing that stood out is how much different sebbs car sounds to Marks.
i was in the main stand right in front of the flying renault and with the cars coming into the turn there sebs car sounded so much cleaner under acceleration. marks stuttered as he applied throttle. also he was close to taking the renault but a yellow flag into the corner stoped any chance of a run up the inside, it took the marshals friggen ages to move the car and by then his tyres were gone.
Could've been the fact that Mark's KERS wasnt working and Vettels was most of the race?
As for the stutter though who knows...
prac 1 was not pleasent viewing... for sure
Mclaren and even Merc closed in druring prac 2. Gut feeling is that both bulls will walk this one
Only hope now is that they lose some track position going from the start and hold them up for a while. History shows that inevitably one of them will snap.
Mclaren testing out all the new parts and then say they do know if they worked, is a bit amature.
Ferrari look fucked again
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
