Well if you can't get an RBR out of Q1, even without KERS, and on the harder tire, you can't really say too much...
Exactly...they were saying that kers gives a 0.3-0.4 sec advantage on this track...webber wasn't even near that...excuses again...
So hoping Vettel doesn't just drive away again. Would be great if his kers bails and that long straight serves as a battle ground between Button and Vettel. That might be asking too much though? Do the other back-runners have kers? Are they going to launch past Webber like last week? Hopefully he recovers well, it's going to be a bad GP for him and he'll be fighting all afternoon, but i bet he'll get some points out of it, assuming no-one takes him out.
Look forward to reading about wtf happened with that tyre choice and lap time.
KERS is no excuse for being that far down the field.
i wanna see him do well....but it just keeps going backwards. I'd say if he doesn't do well this year he should/will retire......or they are deliberately making his car suck balls so he can help hold the rest of the pack back so Veetool can win easier, and to give them an excuse to ditch him next year for someone else? Barichello maybe? he likes being second fiddle to German elitists doesnt he?? :domokun:
either way...i dont see it hapeneing for Webber. maybe he needs some prettier arm candy to BOOSt his confidence?
theres already enough ballast in the drivers seat holding that car up
Bahahahahahahahahahahahahaha
Poor webber, I feel sorry for him sometimes. He's certainly one of the best drivers, but he's never had luck on his side.
Redbull's now the top team, they may want someone like Di Resta, Petrov or Rosberg for some new blood in 2012. Though ferrari still stick with massa (I think webber>massa though)
Edited by Galois
Cause Weber will be holding a lot of Vettel's challengers back from 18th position on the grid. Unless he lassoos the cars in front to get a bit of a run up the straights.
WTF with Weber? wrong tyre choice,be interesting to know the real story on who made the desision. Not suprised to see KERS not working on mark but just fine on sebs, same cars my a@$
I'm mystified. The simple fact is an RB7 should be able to get into q2 on 7 cylinders, never mind hard tyres. And mark's a better driver than that ... at least, I've always thought he was. He's still the same guy that came close to winning the title last year, but I have to ask if his head's right. I wrote off Australia as a one-off, in Malaysia he was screwed by the KERS failure, but I can't think of any reason for this qualifying performance except him being out of the game mentally. He can fix it but he needs to take a good jar look at himself, I think
Webber also only managed 5 laps in P3 and only one of those was a timed lap, seems something has been up with his car all weekend he was way down in the other practise sessions as well. Whatever the cause without KERS here it will be a very long day for him.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
