I'm with roy. it's grasping at straws a bit but if vettel were to get injured (say in the carpark at hungry by a aussie webber fan?) and was out for 4 races it's not unreasonable to see webber winning 3 or even all 4 of those races (given how many second places he's had behind vettel).
lol 1
fat lady has not sung yet.
Mateschitz is the one who said they don't have team orders... He's apolitical animal saying what the punters want to hear to calm everything down.
Edited by hrd-hr30
Yeh, well come Hungary, I am pretty sure the local constabulary are up for a bribe or three...so if Vettel is going to get hurt I best pay for my passage out of the country before I meet him "under the fig tree". I make no promises that I can sort the fit little bugger out but will give it a nudge. Hopefully he cant take too many punches because I get worn our and bored quick.
I am just concerned mid prodigious beating he wins me over with being a pretty cool fella and then i get all guilt ridden and hit the sauce to repress my guilt....actually, that doesnt sound like too bad a result either. :)
Hey, I didn't see where it says we should all start thinking rationally, OFF WITH HIS HEAD.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
