drs for singapore gp.
Wonder if drs will make much difference there? It's a tight corner and not a massive straight wo they won't be going as fast, but then again they'll be running more downforce because it's a tighter circuit
My tips are in...yet another GP weekend where my money on Webber storming to a win...you read it here first.
if you stopped betting on Webber winning, you could have bought an RS500 Sierra instead of the base version :nyaanyaa:
umad coz you don't see Hamilton as being worthy of his drivers title?
no
imad because he is a great driver, a driver who has the potential to be one of the best, but like all drivers he makes mistakes......fair enuff.
my problem is when he does make a mistake he automatic blames everyone else (as if in his mine he can do no wrong) and then when he is proven to be wrong he mopes around as if he is about to cry
and of course there's the 'it's cause i'm black' bullshit.....
Hamilton this year displayed he has the ability to match seb (and beat him to) but is he in a place to challenge for the wdc???? no because he spent most of his time winging and complaining (hence sob)
bottom line is if Hamilton wasn't such a sob he'd be second in the wdc and we would have had a better end to this season (him too).
do you see now?
end rant. :rant:
Hamilton this year displayed he has the ability to match seb (and beat him too)
you never picked up on the 'is it because I'm black, yo?' thing being a tongue-in-cheek jest?
Vettel's leading because he's a great driver in this season's greatest car (Mark having the same equipment, but being (on balance) an inferior driver)
I'd be willing to bet Hamilton would be leading if he had a whip like the RB7 that was capable of being around half a second quicker in qualifying at pretty much every track
None of the rabid haters do.
fixed that for ya
fixed that for ya
all the other f1 drivers would to.
That is the most dishonest statement Ive ever read posted on a forum! Hamo farked up 2008 when he had the best car in the field and a team mate that couldn't even get on the podium most races (7th in the WDC for farks sake) He is a 3 weekend a year man at best. No crime, but his head is often too far buried in his own ass. When his head isnt jammed in his ass he is usually talking out of it!
Webber on the other hand still has to contend with being far more manly then Vettel who is built like a school girl, vs Webber who has a good 13kg of testicle in the car every weekend he has to race. The team know that Vettel gets hysterical and far too charged on estrogen when they let Webber beat him....and you can imagine an F1 team with all that manly goodness just cant handle a winging mole in the pits so all decide its best to let Lady Vettel have her way.
dishonest?? hardly
he won the title in '08, so I'll assume you meant '07. if the MP4-22 was the best car, Alonso should have walked a third title after coming off back-to-back WDC's with Renno
Webber's stock on Wall, balls-wise, done shot way up in my books after his refusal to bitch-out to Gonzo on the way in to Eau Rouge. that would have been the mother of all accidents had Fernando tagged Marks tyre rejoining the track.
summed up nicely bris.
yep, one of your best.
Must have been the "13kg of testicle" that usurped control of the vehicle when he passed Alonso at Spa!
Edited by hrd-hr30
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
