No to the sandbag. Mac's are genuinely quick and LH has let P1 slip through his fingers.
Yea, I just heard vettel saying they had to bring a new front wing from the factory. So I guess they were on old spec gear after the Practice 1 incident.
Bit of a balls up from Lewis, could have made the line comfortably if he wasn't dozing. Little wonder that Webber and Schuey scrambled to get past him.
Edited by irokin
lol everyone knew the chequered flag was about to drop except him! Even when he's having a good weekend, he still manages to find a way to balls it up lol
Was great not to have to hear webber umm and err his way through another interview, its gotten to the point where i cant even listen to him speak anymore
Speaking of annoying, i've put some cash down with a mate on what vettels post race rant will be; "thats what im talking about" is where my money went
MW in 6th will drop him right in the middle or just behind Kamikaze and Von Richthofen off the start.
Of course, I am predicting a massive start from MW now that the guy in the RBR manning the remote control go slow button (I'm glad Roy brought this up) won't have to use it since there is no chance MW will compromise Beiber.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
