I remember reading the somewhat winding story about that connection a while back, but seem to remember it involves the Honda family and some drama/espionage. bit boring really.
Mugen was founded by Soichirio Hondas son. They damn near won a WDC in the Jordan with Frentzen of all people.
lolwut?
McLaren have had heeeaps of different engine suppliers.
Tidbit: Chrysler/Lamborghini almost ended up as an engine supplier, and the team built a modified MP4/8 to test their 3.5 V12 in
Yes kiddies. They started with all sort sof oddball stuff. Got good with the DFV's, spent huge amount of TAG money to get Porsche to build the V6 motors from 83 - 87, then went Honda, Ford, Peugeot, Merc.
^I was just reading about that (good old wiki). More tidbits: they went with Peugeot instead, but after a year of poor performance changed to the mercedes engines.
Interesting reading
Yes- Went from a 3.5L Ford-Cosworth V8 in '93 to a Peugeot V10 for '94; Which my McLaren history book tells me made 100hp more (740) from the same capacity than the V8 did.
Bollocks I say. Everyone was down on the Ford motor. But the packaging advantages and the massive torque made up for the hp deficit. Not that it was ever what the French made it out to be. In any case the engine McLaren ran was to an older spec than the one in the Benetton. True story.
Edited by djr81
If you count a total of 42 points as 'not finishing a race'
not a good season tho
The point wasnt really whether or not the motor somehow once or even twice hung together for the length of a GP. Really McLaren went from belting everyone with a Honda motor to being thereabouts competitive with a second string Ford to being hopeless with the Pug. It got worse in the first year with the Merc - even the fat boy special they made for Mansell was hopeless.
Edited by djr81
1!
Exactly. If they were really up on power and reliable do you think the team would have binned them? The Peugeot motor was unloved at McLaren, tolertated/suffered at Jordan until they got the Mugen (at the time it was effectively a factory Honda engine but out the back of the factory through the family ties at Mugen)and Prost never went anywhere.
Hey, I was just stating the bare fact that the Pug 3.5 V10 made (as far as McLaren's own information indicates) 100hp more than the same displacement Ford V8.
It's not like I'm some Peugeot motah fan-boy.
(a quick look at the wiki link reveals a grand total of zero GP's won via Pug power)
Nah and Im not either. Just trying to point out you shouldnt confuse PR bullsht with reliable engineering. There is much more to an engine install in an F1 car than horsepowers on a dyno. Honda had to learn that. Ron Tauranac showed TWR (of all people) that with the Yamaha in the Arrows. Not that it needed proving but the Renault motor has also proved it over the last few years.
If you want to see a good motor have a look at some of the massive aluminium Chevs McLaren used in the M8's and later. Or the Repco motors in the Brabhams. And yes I am an MRD/Ralt fanboy.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
