Watched it in Thailand, was great not having to listen to the one hd nobs, and nowhere near as many ad breaks
I'm off to Thailand in November. I hope the rain stops soon but if it doesn't then at least Abu Dhabi is on for the first weekend which is in Bangkok.
the fu(k away from our thread Darryl
I still love when he says it. Beats me why someone hasn't told him.
Maybe if Ricky has a good run between now and then they can dump the spacer in the other car instead.
You heard it here first
As I hoped, HRT have seen sense and dumped Leeoozee instead of Ricciardo. Liuzzi's days are obviously numbered, whereas Ricciardo is going from strength to strength. Can't wait to see him out of that tractor and into a real car!
update on Kubica. :)
Our goal is to get him back in F1," ESPNF1 quotes Ceccarelli as having told Lucca television. "But he will still need a few more months of rehabilitation."The cuts were so bad that many colleagues and specialists had ruled out a return to the wheel for Robert.
"But, clinically, little by little everything has improved and the hope to see him driving as soon as 2012 is becoming more and more concrete."
officials confirmed plans for a New Jersey GP in 2013.
"This is going to be an economic boom for this whole region. While political and public servants talk about creating jobs, the governor has put the pedal to the metal and delivered," Roque told Reuters.
"This is the top of the line in motor racing, it's incredible."
New Jersey governor Chris Christie is set to announce the deal in Weehawken, New Jersey, on Tuesday.
Joe DeMarco, an attorney with West New York, says it will be a long-term project.
"It will provide a very challenging course - they compare it to Spa in Belgium, but will have the feel of Monaco," said DeMarco.
He added: "It has been contemplated to at least run for ten years but there are options and so on depending on the success of it. Hopefully it will be a long term event, embraced by residents and the community."
as good as spa and the feel of monaco...... yer sure. :rofl:
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
