webber testing vettels next tyres
loving the donkey work
lol yeah, even when trying to get second in the championship they still try to find ways to let vettel win.
webber v alonso
lets hope it go's better then the sob v massa.
webber v alonso = big ball moves by webber
1) Webber doesn't need the team to help him lose, he does a brilliant job of it all by himself.
2) He'd have to actually close the gap rather than increase it first...
