So the real issue is they're two hacks who somehow found themsleves in good cars, and are fighting with eachother sorta kinda but not really toward the front? :P
Put both of them in something like a HRT and they'd be berated out of the field very quickly.
I've faith he and Jenson can take the fight to RBR next year.
Massa, on the otherhand, will always suck.
yeah, Massa sucks so much Hamilton needed a Glock gift on the last lap of the season to stumble over the line 1 point ahead of Massa to get his one and only WDC.
Not long after that Massa had his accident and hasn't really been the same since. What's Louise's excuse? His fake girlfriend's leaving him?
Could be post of the season.
Maybe putting up with her shit has been the root cause of his problems?
Forget the bitchez in 2012 and focus on the racing, son.
Too much 'root' or not enough? :rofl2:
Edited by 260DET
One can only assume Massa has Polaroids of someone deep inside a goat.
Stefano was sitting by himself shaking his head wondering why it was that Spiro had to build hundreds of houses before he was known as Spiro the House Builder, Peter had to build hundreds of boats before he was known as Peter the Boat Builder.....
....but you f*ck just one goat....
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
