Massa's origianl contract extension was because Nicolas Todt is his manager. His father approved the contract, it seems, as a final fcuk you to the team before he left
He was then saved, ironically, by getting hit in the head by Rubens' rear spring back in '09. I think Di Montezemolo realised that his team would not be looked on favorably by the general public if you turfed a guy that almost died for your team
His form this year has been horrendous, and replacing him with a younger, faster more marketable guy can only bring good things for the fuzz
it was just clumsy on Hamilton's part (again!) - yes, at one point he was in almost to the front wheel, but then half backed out and the collision was Hamilton's front wheel on Massa's rear. Its not really an overtaking area - if you're going to do it there you really need to make it a dominant move, clearly in front. He didn't. His move relied on the other driver getting the f*&% out of his way. He had to know Massa was not going to do that!
On the other hand, I feel it was pretty deliberate from Massa - he definitely saw him going up the inside but gave him the big "f*&% you"
You know its a strange call when the pommy BBC commentators are amazed that Hamilton didn't get penalised.
massa should join a closed wheel racing category. then he can shut the door as hard as he likes and not tear wheels off, etc.
and hamo and massa need their own tv show. it would be like a young version of grumpy old men
gee, wonder where you came up with that idea... its not like people have been saying that about Hamilton all season or anything
Pastor will use a ninth engine in Abu Dhabi, due to damage incurred following the gearbox failure in India, he will therefore incur a subsequent 10-place grid penalty. Rubens will use a new eighth engine
can it get much worse for Williams this year?
dc commenting on sob v massa.
"I simply can't understand how Felipe could have been deemed the guilty party. As drivers we are always taught that the car behind is responsible so to my mind the stewards misinterpreted what happened,"
"I don't want to beat up on Lewis. Far from it. "I supported him in similar circumstances after Sauber's Kamui Kobayashi clipped the back of him at Spa. And after everything that has gone on over the past weeks and months he deserves a break. But in this instance I feel he was definitely the guiltier party.
"If Lewis had got that far up alongside Felipe into a tight hairpin, where the braking zone is maybe 100 metres and lasts for a few seconds, then I think Massa would have been right to give way. But heading into a fourth gear left-hander at maybe 150-160km/h? Where the braking zone lasts for one second? I don't think Massa can be held responsible."
"This isn't really about Lewis and Felipe. It could have been any two drivers. What concerns me more is the inconsistency of stewarding decisions," he continued.
"Making these types of calls is one of the real difficulties with a complex sport like Formula One, but it was almost as if they felt that - with Lewis receiving so many decisions against him this year - they were trying to redress the balance. A bit like in football when a referee sends someone off in controversial circumstances and the crowd is on his back, he is more disposed to send a player from the opposition off."
they're currently on course for finishing the season with less than 10 points. even STR have 8 times their current total ffs.
in Latin you'd say they've had an annus horribilis
cool video Hansel
next year when Williams gets rid the cosworth and puts the renault in, it will be much better for them imo.
and when they pry the old Brazillian out and ship the quick Finn in that's bound to help too
cool video Hansel
true that.
Johnny Herbert ( driver representative on the stewards panel in India) on sob v massa.
"I know Massa was upset by our decision, but I believe we made the right call. After looking at it from different camera angles and studying all the data available to us, it was clear that Massa knew where Hamilton was before he chose to turn across him."There was nothing Hamilton could have done to avoid it. He did try to get out of the move, but it was too late and the contact was made."
Wise words from DC.
Simplistic dribble from Johnny Herbert.
Yep
Sounds like nothing more than the stewards defending their bad call.
What he's basically saying is that any driver coming from behind can drive up the inside, with no chance of making the corner, and the lead car who is on the racing line either has to stop and let him through, or drive right off the track so that he doesn't get t boned.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
