You think vetel had any actual problems? Seems like Redbull's brand of team orders. :cheers:
Work. Hmmm I'll go in later. Hopefully nothing major goes wrong and no one notices I'm not there till early afternoon. :whistling:
Edited by gts-4 dreamer
If it helps, I got my 3 day general admin pass to Monza this year, from here http://italiangp.it/index.asp. Although I'm not sure if they're selling 2012 tickets just yet. Also, they only send out the tickets about a fortnight in advance of the actual race. So if you're already going to be overseas at this time, it's just something to keep in mind. Good luck. It's an incredible weekend. Oh and Webber ftw.
Whats dissappointing is that even after 19 races, the gaps between each of the front runners has remained fairly static
Bulls out in front
Mclaren challenge 50% of the time
Ferrari picking up the pieces
Mercedes bringing up the rear
9 months of knowing pretty much how the race was going to end up, short of rain. Unless somebody does something magical between now and march, im expecting next year to be a carbon copy. The in season testing ban has stopped any kind of significant performace mix betweeen teams.
If Vettel wins by some margin in Melbourne next year, i might start giving some of the races a miss next year. Monza and Valencia for example. Just have to wait it out and hope for the best with the turbo era
Every race is a bit much
I cant see why they couldnt run a few days testing after a grand prix weekend. Tracks already setup, teams are already there and fans could get tickets to it or something
Have like... 4?... of these spread evenly over the course of the year and BAM. Low cost, easily organised, everybody is happy
How fcuking hard is that?! Who need Jean Todt when im giving these pearls out for free
How did you find Monza? I thought the way the GP was run was hopeless. Wasnt great for spectating or easy to get around. And Milan was nowhere as much fun as say Budapest for nights out
It's the only GP I've been to, so I don't really have anything to compare, but I enjoyed it. I used public transport to get to and from Monza from Milan and it became a bit testing as the crowds grew. But you are right, Monza park is a massive venue and getting around can be a bit of a logistical nightmare. From a spectators point of view it was pretty poor. From any decent vantage point you could only really see a very small section of track and often without the big screens in view. And after going on to Paris after Milan it made me realise how much of a crap factory Milan was.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
