You think vetel had any actual problems? Seems like Redbull's brand of team orders. :cheers:
Work. Hmmm I'll go in later. Hopefully nothing major goes wrong and no one notices I'm not there till early afternoon. :whistling:
Edited by gts-4 dreamer
If it helps, I got my 3 day general admin pass to Monza this year, from here http://italiangp.it/index.asp. Although I'm not sure if they're selling 2012 tickets just yet. Also, they only send out the tickets about a fortnight in advance of the actual race. So if you're already going to be overseas at this time, it's just something to keep in mind. Good luck. It's an incredible weekend. Oh and Webber ftw.
Whats dissappointing is that even after 19 races, the gaps between each of the front runners has remained fairly static
Bulls out in front
Mclaren challenge 50% of the time
Ferrari picking up the pieces
Mercedes bringing up the rear
9 months of knowing pretty much how the race was going to end up, short of rain. Unless somebody does something magical between now and march, im expecting next year to be a carbon copy. The in season testing ban has stopped any kind of significant performace mix betweeen teams.
If Vettel wins by some margin in Melbourne next year, i might start giving some of the races a miss next year. Monza and Valencia for example. Just have to wait it out and hope for the best with the turbo era
Every race is a bit much
I cant see why they couldnt run a few days testing after a grand prix weekend. Tracks already setup, teams are already there and fans could get tickets to it or something
Have like... 4?... of these spread evenly over the course of the year and BAM. Low cost, easily organised, everybody is happy
How fcuking hard is that?! Who need Jean Todt when im giving these pearls out for free
How did you find Monza? I thought the way the GP was run was hopeless. Wasnt great for spectating or easy to get around. And Milan was nowhere as much fun as say Budapest for nights out
It's the only GP I've been to, so I don't really have anything to compare, but I enjoyed it. I used public transport to get to and from Monza from Milan and it became a bit testing as the crowds grew. But you are right, Monza park is a massive venue and getting around can be a bit of a logistical nightmare. From a spectators point of view it was pretty poor. From any decent vantage point you could only really see a very small section of track and often without the big screens in view. And after going on to Paris after Milan it made me realise how much of a crap factory Milan was.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
