  • 3 weeks later...
So Sard 700s and Nismo in tank should be ok for a 50% mix?
Can't see why not, I do have a sard reg as well but it's set at standard pressure so doing exactly the same thing as a stocker :)
Bris guys are making 370-380 killerwasps on straight E85 on RB26s using 700's you "should" be fine with the little 2L and that pump.
Yeah, it's only people like Elite Racing that seem to have issues with injectors/pumps not flowing. I have a feeling it might be the tradie and not the tool in that case haha
Hey thanks for the plug.
BTW, when I called you out on it via PM, you never got back to me with those figures? You might wanna back up your mouth with some facts before you get into an argument you can't win
I guess it was a bit of a plug, mind you I always thought that being infamous was not all it's cracked up to be.
I gave up getting back to you with evidence after you said the dyno figures were inflated, the mph of the trap speeds were fake and just generally everything that I showed you was impossible!
But hey, I have every reason to lie about it...
...wait actually I don't!
Edited by SimonR32
why on earth would anyone go to the trouble of making a fake 1/4 slip
That's the point, he never showed me anything,
He's real good at running around like a school kid dropping smart ass comments but when you call him out on it he backs out and runs away.
You never answered any of the questions I asked you on injector size or open time and did nothing but comment on how many dynos read the same figure.
I told you before, until you have PROOF of your claims, then don't make comment on advice I give or information I provide.
Another update, have not driven the old girl for a fair while now because I decided to get some decent coilovers to replace the mismatched pairs...
Was going to get a set of BCs but ended up with a Set of Greddy Type S. They are a lot better than the old set as they are base adjustable, damper adjustable and also have tapered rear springs!
Busy setting the ride heights at the moment (did rears last night) and have had a few quick test drives on them and they feel and handle a lot better so I'm very happy :)
Also tried to install the JJR castor rod brace but it fouls on the front standard swaybar. I'm assuming it's because of the amount of front castor and camber I run, has anyone else had this issue before?
Edited by SimonR32
  • 3 months later...
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
